โSep-13-2020 01:30 PM
โSep-14-2020 05:45 AM
carlos6466 wrote:
I removed and replaced the one way valves (back-flow valves) on the end of the inlets as one was defective yet water still is only a trickle.
โSep-13-2020 07:17 PM
โSep-13-2020 06:41 PM
โSep-13-2020 06:40 PM
Lynnmor wrote:
Follow the line from the city water port to the first fixture, there must be a restriction. If you were to remove the cold water line to the water heater and back flush from there with the city water port check valve removed, maybe you could dislodge debris or at least check the flow. Another method would be to connect a garden hose to the cold water low point drain instead of at the water heater.
โSep-13-2020 06:12 PM
โSep-13-2020 05:47 PM
bigorange wrote:
Agree with what other have said...assuming you bought it new, Iโm betting on a debris clog somewhere between the inlet and the supply tee. Is there an in-line filter or strainer that might be clogged? Our trailer had several lines and one faucet that were slow flowing due to debris from manufacturing.
โSep-13-2020 04:34 PM
โSep-13-2020 04:27 PM
โSep-13-2020 03:05 PM
โSep-13-2020 01:59 PM
