Thanks for all the suggestions. I hate electricity because it is all inference, since you can’t directly observe it. If I’m not mistaken, the breakers are for the 110 AC circuits, and they won’t cause a draw on the battery. There are also 12 fused 12V DC circuits in the panel for interior lights, etc., which all seem to be disconnected by the battery cutoff switch, so it won’t be those circuits. The Co2/LP detector has a light indicating when it is on it is on, which is turned off by the battery disconnect switch, and also I don’t think it would draw 1.5 amps if it were functioning correctly. The radio doesn’t come on with the battery cutoff switch off. The inerter doesn’t work with the battery cutoff switch off, so I assume (maybe erroneously) that it isn’t drawing any power. I probably don’t understand how circuit breakers work, but when the breaker tripped wouldn’t the battery drain stop until it reset, and then the drain would make it trip again? This drain is continuous until I measure it with my meter, and then it does away for a few minutes and then reappears. I’ve contracted Progressive Dynamics who make the converter, and they tell me that the converter has diodes and fuses which prevent it from creating a draw on the battery. I’ve emailed Host and received a reply from Randall Pozzi, General Manager, but it wasn’t much help. (I asked for the wiring plan they used when they built the camper and he responded that they never had one.) And I’ve received no reply to my second more detailed email asking some of my questions below. As I’m sure you all know, one problem is that camper electronics are, as we used to say in construction, “10 pounds of s**t in a 5 pound bag.” Really hard to access, no wires are labeled, etc. Anyone know anything about these two questions, which I also asked Host, which might help.
1. Where is the controller for the slide out motors? The wires for the switches which operate the slide outs seem to disappear into the unit in the area under the bathroom. You can’t see where they go through the (totally inadequate) access panel. I would like to be able to rule out that circuit by disconnecting the power to the controller. Or, where is the circuit breaker for the slide out controller?
2. As you look into the access panel below the camper door, on the left are two panel boards. The lower one controls the jacks. The battery draw remains even after the 12 volt and ground are disconnected from this panel board, so that’s not the problem. Above this panel board is another panel board. It has an upper and lower plug with numerous wires in each. Next to each plug is a plug in circuit breaker. There are also some other devices plugged into the panel board, but I’m not sure what they are, maybe relays. Of course, nothing is labeled. Can you give me any information about what circuits are controlled by each plug or the associated breakers or the other devices in the board?
Can anyone recommend an RV repair place in or near Santa Rosa, CA with a tech who is really good with RV electronics? I’d go as far as I need to for the right person (not right away though, I’m off in my trailer for some trout fishing next week.) And yes, that is my Host in the storage yard off Santa Rosa Ave.
