Oct-22-2014 02:50 PM
Nov-06-2014 11:30 AM
Whitehawkmn wrote:
Thank you all for your ideas. And yes I did follow the instructions on setting up the hitch from scratch. But when I do, that's when I get more sway. In the spring I'm going to try a few different things. I may look at going back to what I had and taking out 1 washer to help with the grinding and popping.
Nov-06-2014 11:27 AM
Nov-06-2014 03:58 AM
Whitehawkmn wrote:
I forgot to put that info, sorry. It's a Jayco Whitehawk and I've tried keeping all the heavy things in the front of the TT.
Nov-06-2014 03:35 AM
Nov-05-2014 10:45 PM
Nov-05-2014 05:02 PM
Oct-23-2014 01:25 PM
Jay Flight 33RLDS wrote:
I have an Equal-i-zer®'s 4-Point Sway Control system. My dealer did not install mine correctly. They too set the front of my trailer too low causing the Sway control brackets to pivot forward while bending the pins even though the trailer towed decent. I moved everything up one whole, Sway control brackets and the tow Shank. I also use a pair of Sway Bracket Jackets available from their site. The popping and cracking is gone, the Sway control brackets don’t pivot and my pins don’t bend any more. The trailer feels much more stable and not as heavy, dramatic improvement. I used the installation instructions, also on their site, as my guide so I didn’t get about of their specs.
Oct-23-2014 12:14 PM
Oct-23-2014 11:08 AM
Oct-23-2014 11:00 AM
Oct-22-2014 08:01 PM
Oct-22-2014 06:39 PM
Oct-22-2014 04:51 PM
Oct-22-2014 03:01 PM
