EternaBond
Rubiranch
this is new to me
can someone post a picture of what it looks like after you put it on??
thanks
Camp Host, from the other side.
10 REPLIES 10
Rubiranch
WOW!! thank you everybody -
downtheroad's picture is just what I was hoping for - it looks great
my camper is 20 years old and I'm not sure the previous owners ever even covered it - all things considering the seams are still pretty good - I was looking for something to cover them before they start leaking - this looks like it will do the trick
thanks again
Tom_Anderson
towpro wrote:
Is it OK to overlap eternabond, layered with top piece over bottom piece, like you would stack flashing?
Yes.
towpro
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
Buzzcut1
Nomad II
Nomad II
it amazing what you can fix with eternabond tape and some dicor. My wife scraped the edge of the TC on a tree branch and tore the rubber roof alond the corner, ripped the molly rack loose and peeled oper the rear corner. I resealed it with the tape and then put dicor at the tape TC interface to prevent peeling. That was in early 2015 no issues since then
eternabond in place
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Tizi
2008 Dodge Ram 2500 QC 4x4 - HEMI
2007 Northern Lite 10.2 RR
Tizi's Transformer by Whazoo
CAJW
towpro wrote:
I guess its time to try Eternabond.
anyway, does anyone on here have a reason I should NOT use Eternabond? It is all its cracked up to be?
Should I be adding that to my Arctic fox before I find a crack in the factory sealant?
That's what I did before any significant weathering of my caulking on our new AF 996 occurred. I still inspect and caulk any untaped areas, but after 3 years (stored in an enclosed building) the tape looks almost as good as new.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
towpro
I got a problem with an Open Range. The front edge (like shown above) is just caulked, but over on the side where that edge, and the rain gutter, and the siding, and the front cab all come together, there is a crack that keeps opening up every 2 months. nothing I can put on it will not crack. Now water has stated to get down into both front corners on side and the RV looks like ****.
I see something on my Open Range slide out roof that appears to be eternabond that seals the roof onto the outward flange of the slide ou
I have used it under solar panel mounts, but if it was so great, why don't the manufactures put it on that front roof to cap joint on all the RV's?
I guess its because of cost, and the factory joints seem to hold up (for the most part)?
in fact here is a picture of my problem area.
looking at RS of long gray piece that sticks out in photo, you can see the crack. this picture was before I cleaned it up and resealed it again in November.
2022 Ford F150
IAMICHABOD
To see what it looks like applied Google is your friend
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
downtheroad
It comes in different lengths and widths.
Eternabond......HERE
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
ScottG
It just looks like white tape.
It's very important to follow the directions to the letter. This includes cleaning and pressing or rolling the tape after you stick it down. This is the way you activate the real adhesive in it.
