F250 6.2 gas Towing heavy with 3.73 rear ??
Learjet
Looking at a mid profile 5th wheel:
Trailer:
-36 ft.
-Unloaded 10,000 lbs
-GVWR for Trailer 12,255
-Pin weight 1,800 unloaded
Truck:
-6.2 with 3.73
-12,400 limit for 5th wheel
-payload per scale with me and full fuel 3,140 lbs (door jam is 3,253 lbs )
...I will add timbrens and will be close to max payload (once I load the trailer).
...towing flat land in Louisiana 99% of the time and I'm not looking to drag race......AM I CRAZY ? :@
this should be good for 5 pages :E
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
35 REPLIES 35
WoodedOne
No problems -- I tow 1000 lbs more than you with the same truck. Michigan to Florida, 65 MPH on any hill. I will lock out 6th gear if I am the 'sine wave' hills, but on calm days or with a tail wind, she will do 65 MPH in 6th on her own. I added extra leaf springs to make mine a F350 equivalent, and man what a difference, barely squats now.
RinconVTR
ib516 wrote:
You only weigh 110# :h
I think you misinterpreted his posted weights.
Denny___Jami
To give you a example our 6.2 with 4.30 gears is rated to pull 15600 at that's what we pull with it.
I second changing to 4.30 if you feel you need them, cheaper than a new truck.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
Learjet
MFL wrote:
If you had the 4.30s, it would be no problem at all.
If 2wd, it would not cost that much to change gearing, if you feel the need.
Good luck,
Jerry
That would be a good plan should I see the need for 4.30s after I get the trailer.
Truck is only 2 years old and 20,000 miles, so I'm looking to keep it for a while.
B&W Ram Companion
MFL
Nomad II
Nomad II
You will likely have to lock out 6th, towing in 5th should work on the flats most of the time. In a strong wind you may be towing in 4th, but should be do able.
Good luck,
Jerry
