Folding cargo / tire carrier
barely3
I am looking for a bumper mounted cargo / tire carrier for my travel trailer. I have seen them on a few trailers but cannot find a supplier for the carrier itself. Any ideas?
11 REPLIES 11
SprinklerMan
That thing on the rear of the trailer is a sewer hose carrier . Not a bumper
TravelingTeache
Ditto on the bumper not being strong enough. Hubby had to remove and reconfigure a shelf he put on ours to hold a box of gear and eventually a generator. Lasted about one week into the trip, then into the truck bed it went!
2003 Timberlodge Travel Trailer
2015 GMC Sierra 2500 HD Diesel
The Traveling Teacher
hddecker
X 5 on the usual trailer bumper is not strong enough. They are there just to look pretty.
I have seen bike racks that have caused the bumper to fail, due to stress fractures.
Mike_LA
Racks on this page.
Mike
2006 Chevy Silverado 2500HD CC/LBZ Duramax
2017 Hyper Lite XLR 26HFS
Previous Trailers:
2003 Aerolite 24RK
2006 Rockwood 3115SS TT
2006 Rockwood 8283SS FW
2005 Jayco Talon ZX24E
2012 Sunnybrook 26FBS
Dakota98
You make a good point & anyone considering these add on's should first check the stability of the 4" bumper tube before mounting anything to it. I imagine some campers with this type of bumper are not suitable for mounting, as you indicated, being that they are made of light weight materials. My bumper is heavy gauge steel reinforced & is welded to the rear frame rails of the trailer.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
opnspaces
Navigator II
Navigator II
Dakota, you might want to reconsider that receiver tube clamped to the rear bumper. more often than not the rear bumpers are just folded sheet metal that can barely support themselves. If you are going to run a carrier I would look into having the receiver attached to the trailer frame rather than the bumper.
Dakota98
I just mounted a tire carrier to my rear bumper (square tube) made by Ultra-Fab. You can get them through Amazon as I did for about $38. Mine is a fold down style, as I have a rear cargo compartment door. There is Also a"fixed" version for a few dollars less. Ultra-Fab also makes a receiver tube that mounts to your square bumper for mounting a cargo carrier, I did that also, it is offset from center just a little to accommodate the tire carrier. It will run you about $38, either on Amazon once again or Ebay. My cargo carrier was purchased from Harbor Freight . I purchased a ATV carrier since it's design allowed for the cargo carrier & tire carrier to both be mounted at the same time without any modifications.
2006 POLARIS ATV
USMC 68-74
TNRIVERSIDE
CaveRun wrote:
I just ordered one from eTrailer.com.
http://www.etrailer.com/Trailer-Cargo-Control/Ultra-Fab-Products/UF15-954730.html
Looks like a good product and reasonably priced. 60 lbs capacity is the limiting factor.
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
CaveRun
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
Aluminum_Siding
yes not the bumper but the frame or even go from the bumper to the frame with welded supports. I'm having my bike rack mount (2 in receiver)attach to the bumper with a reinforcement welded from it to the frame.
Peg_Leg
Most square tube bumpers aren't strong enough to support much weight. I would suggest you find a metal shop and have them fabricate something that would attach to the frame.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
