โMar-16-2023 09:36 PM
โMar-22-2023 02:26 PM
โMar-22-2023 01:29 PM
StirCrazy wrote:
oh I think ford would love to have forscan shut down but hey haha.. I have been using if for about 5 years now... can't change anything in the engine control module so you can't tune with it but you can turn on off in almost any other controls.
โMar-22-2023 08:00 AM
โMar-22-2023 07:15 AM
Grit dog wrote:
^Well thatโs awesome that FoMoCo allows the consumer to access the software previously reserved for dealer services.
Hard to believe theyโll allow all the available configuration changes that โcanโ be made but donโt necessarily conform to any or all local or national regulations.
Seems a liability if theyโre allowing things like changing tpms thresholds, drls, fog light activation, stationary dpf regens, imperial to metric gauges, etc, to name a few.
But if thatโs the case, thatโs HUGE for the diy type Ford owners!
On another note, the lack of ITBCs in Covid era trucks could be due to supply chain issues I wonder? As it was definitely not the norm to see any HD pickups especially those apparently specifically equipped to tow heavy, like the previous example, without ITBCs.
โMar-21-2023 11:46 AM
โMar-19-2023 08:03 AM
โMar-19-2023 06:58 AM
โMar-19-2023 05:00 AM
โMar-18-2023 04:53 PM
โMar-18-2023 03:54 PM
MFL wrote:Grit dog wrote:
^So youโre saying the new Fords that donโt come with an IBC donโt come with an adapter and are no longer plug and play?
Thatโs horrible. Installing a brake controller in every brand of truck for the last 20+ years has been a snap.
My recommendation was considering that the OP does not appear equipped to do any sort of moderately involved work. And traditionally, adding an aftermarket brake controller was about as easy as falling off a log with no calks.
Not what I'm saying, didn't mean to stutter.
To clarify...IDK if OPs truck came with the OEM adapter, but I think it is likely. The OP would have to do same dash disassembly with either BC, in order to access the OEM port/plug. While the IBC module/controller attaches right to the waiting plug, the P3 would require using the Ford adapter, which will likely be 4 simple splices to the P3.
The IBC just pushes into opening, snaps in, done. The P3 needs locating best spot, drill a couple holes, keeping level side/side. Either install easy, but the IBC, just a bit easier, other than going to dealer for flash.
OP said cost not an issue. Personally, I would always spend more for factory setup, that comes with some advantages.
Jerry
โMar-18-2023 06:22 AM
โMar-17-2023 07:37 PM
โMar-17-2023 04:33 PM
Groover wrote:
The factory controller has the ability to access vehicle stability information and take steps to control an unstable trailer. That could be a life saver.
You need to be aware that the factor controller (at least in my 2016) model turns off the brakes below about 3mph, presumably to prevent burning up the brake actuators. There will be times that you don't want that to happen and you should keep a hand on the manual override. Example: coming down a steep gravel drive and trying to make a sharp turn onto a gravel road. I nearly got pushed off the side of a mountain once. It took me a while to figure out why. Any stop on a steep hill while towing heavy can be a challenge. In my case I am towing a trailer about twice as heavy as the truck.
โMar-17-2023 12:36 PM
