Dec-30-2014 12:14 PM
Dec-31-2014 12:55 PM
Dec-31-2014 11:28 AM
agesilaus wrote:
Well a six point would be in contact all the way around the plastic hex. A 12 point would only touch at 12 points around the circumference. Might be a minor point.
Dec-31-2014 10:43 AM
Dec-31-2014 10:39 AM
Dec-31-2014 08:24 AM
Dec-31-2014 06:54 AM
agesilaus wrote:
I really am reluctant to post this since I know it will attract a flock of negative comments. I expect to see: "The Ram fuel filter is made of aircraft grade titanium and is platinum plated too...."
But this is something other 6.7 owners should know. I was taking off the chassis mounted fuel filter housing an hour ago when the plastic 'nut' on the bottom snapped right off. This housing has always been tough to remove and replace. It groans and squeaks loudly as you turn it.
I had it 1 1/2 turns off and was able to use a strap wrench to get the housing all the way off. The strap wrench makes a very poor fit for the housing so this would not be an option to remove it normally.
I've heard on the Powerstroke forum that you need to use a six point socket to remove the housing not a 12 point. Apparently this must be fairly common the Ford parts guy told me that they been seeing this happen and he ordered four housings and has one left.
The new housing comes bare, you need to recover the electical fitting (unscrews easily) and the drain valve from the old housing. Rumor is that it costs $25 for a new housing. Will see in the morning.
agesilaus wrote:
And the Ford housing has a hard stop, so that you have to tighten it down until you cannot go any further.
Dec-30-2014 07:16 PM
agesilaus wrote:
A unreasonable concern I'm happy to say. This housing broke off when it was being removed tho, not tightened. And the Ford housing has a hard stop, so that you have to tighten it down until you cannot go any further.
Dec-30-2014 04:21 PM
Dec-30-2014 04:16 PM
Dec-30-2014 03:22 PM
Dec-30-2014 03:04 PM
Hannibal wrote:
Toyota "hear the angels sing" uses a plastic oil filter housing that will break if you use anything but the proper tool for it. Use the proper tool and life is blissful.
Dec-30-2014 01:21 PM
Dec-30-2014 01:08 PM
Dec-30-2014 01:07 PM
coolbreeze01 wrote:
Any idea what size 6-point socket is needed?
