I Fish 2 wrote:
HMS, you show a picture of the camper setting on the scale. What did it weigh?
I weighed both the old (1998 Bigfoot 9.6) and new (2008 Bigfoot 10.4E) camper.
2500C9.6 front 1550 rear 1200 total 2750
Water and propane, nothing else in it
2500C10.4E front 1830 rear 1740 total 3570
1/2 water, propane, gear but no groceries.
The campers are not that different in size, I'm a little surprised at the weight difference, but those weights more or less match the documentation.
Front was right near the front end as shown in the picture, rear was approximately end of bed. I took actual measurements, it is sitting on a 3x6 so a little bit approximate, from that the CG aft of the camper front bulkhead calculates to 42 inches for the 9.6 and 52 inches for the 10.4.
Part of why I did this is to understand why the 10.4 feels so much better driving than the 9.6. I made some changes to the truck right before I picked up the 10.4, clearly those are responsible for the improvement, not the weight or CG. I had recently changed tires from the original OEM Goodyears to Michelins and inflated them to the same pressure (55 lbs) as called for by the tire chart. However the Michelins are a true 0 deg radial and the sidewalls are squishy, truck drove noticeably worse loaded or empty. Consensus here seemed to be pump them up hard, so I inflated them to 70 and also set the front shocks (Rancho 9000) up a couple notches. So those two changes made the 3600 lb camper feel better than the 2800 lb camper. Now I have 1.5 inch front and rear antisway bars and it feels better still. I never put the 9.6 back on the truck and now it is sold.
There are some other subtleties I would like to understand better. I had to run 40 psi in the air bags with the old light camper to get level. I run minimum (like 5 psi) in them now with the new camper and it is level. There is a lot less pitching with the new camper, part of that must be due to the front shock settings. Two things about the old camper: the tanks were at each end, water in front, propane right in back, batteries up high and back. I also had a toolbox and some heavy steps mounted on the 18" hitch extension, whole affair might have weighed 200 lbs right at the back. On the new camper I can't use that arrangement, and the tanks, propane, and batteries are right at the front and all together. So, worse weight distribution? higher polar moment of inertial? I don't understand it, new camper CG is further back and heavier....
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
