โOct-09-2014 07:31 PM
โOct-10-2014 06:30 PM
nstate wrote:
Seems my propane furnace draws about 8amps while blowing. Doesn't seem like much but on/off throughout the night adds up. Are there any options regarding more efficient blower,mods,etc. Mines a single speed which is just high. Thanks
โOct-10-2014 10:18 AM
โOct-10-2014 10:15 AM
joerg68 wrote:the air moving across the heater transfer system keeps the temp of the burner from not getting far more dangerous for fire potential
I would like to strongly emphasize that. The burner is designed to deliver a certain amount of heat that has to go somewhere. If the blower doesn't transport it away, it will stay there and heat up the furnace. I would not want to find out at what point it ignites the particle board wall of the neighboring cabinet.
But even if that was not the case... A slower fan will take longer to distribute the same amount of heat inside the camper. It might consume less amps when running, but it will run for a longer time. I would assume the fan is already designed by the manufacturer's engineers to work pretty well, so any gain would probably be small.
โOct-10-2014 08:49 AM
โOct-10-2014 08:06 AM
โOct-10-2014 06:25 AM
โOct-10-2014 12:45 AM
โOct-09-2014 09:57 PM
โOct-09-2014 08:56 PM
โOct-09-2014 08:38 PM
โOct-09-2014 08:19 PM
โOct-09-2014 08:05 PM
โOct-09-2014 07:58 PM
โOct-09-2014 07:42 PM
