Gas milage on Ram 2014 RAM 2500 6.4L
samhain7
Hi all.
I know that winter gas is less efficient.
I know that the gas meter lies (but its realvant: if 3MPG off, it is always 3 MPG off)
So, my question is:
Can anyone think of a reason that my 2014 Dodge Ram 2500 6.4L with 103,000kms on it, would start getting worse and worse gas mileage?
When first owning the truck, on average I was around 18L/100KM.
Gradually, I am getting around 24L/100KM.(or around 10MPG) and I am not towing anything. I do know that I have reduced my highway travel a bit, but is anyone else seriously getting this type of result?
I am getting around 500km for 100L of fuel.
My dealership has been zero help!
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
17 REPLIES 17
dodge_guy
eHoefler wrote:
You should be on your 3rd set of spark plugs, they have a 30,000 mile (18,600kms) interval.
6.4 goes 100k on plugs.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Grit_dog
Navigator
Navigator
samhain7 wrote:
Grit dog wrote:
So you've gone from 13ish mpg to 12ish mpg. Change the readout on the dash to oil pressure or tire pressure or something other than fuel mileage. That usually helps with the gauge watching.
I realize it says 24 when it should say 25 (sometimes 26)
That may not seem like a lot to you but with gas prices where I live that is a sudden $8 or more in fuel costs per 100km.
Not sure turning off the display is the best advice.
That was tongue in cheek, but being winter can have a bit to doo with it.
You could be having a slight issue like mentioned above, but at that low of miles and that new, it's unlikely. Check that the engine is getting up to full temp and not unnecessarily running rich. Assuming all other basic maint is up to par.
ib516
30,000 miles is about 50,000 Km.
Spark plug change interval is 100,000 miles or 160,000 Km for the 6.4L Hemi in the 2500/3500 Rams according to the manual.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
MountainAirMan
Has your tire inflation been checked during this period? Any chance you may have some brake pads dragging due to caliper pistons sticking or brake hose internal collapse?
Lyle (the other one)
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
mtofell1
Winter fuel and stop/go driving absolutely kill the MPGs on these trucks. I do a mix of driving and often only see 11ish this time of year. I do a few auto-starts when it's cold too which, of course, kills it further (but at least I'm warm :)) - same truck, 2014 6.4 Hemi 4X4.
camp-n-family
Winter fuel and longer idle/ warm up times.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
ib516
Do you have one of the cr@ppy reusable air filters in it like a K&N?
samhain7
Krusty
Thermostat starting to stick open a bit. Oxygen sensor(s) getting worn. Lots of things can contribute to fuel consumption.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
ksss
Maybe that is why it is running so shitty?
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Grit_dog
Navigator
Navigator
ksss wrote:
I would replace the air filter, plugs/top shelf plug wires) and run some quality gas treatment through it. Buy gas from a quality name (Chevron, Sinclair) and see if you find some improvement.
....Spark plug wires, lol. There is no way that's the problem cause there arent any.
That thing doesnt even need plugs at that low miles, but for the $50 it costs, maybe put new plugs in it.
Grit_dog
Navigator
Navigator
ksss
2013 Fuzion 342
2011 RZR Desert Tan
