Jan-03-2023 06:24 AM
Jan-13-2023 09:57 AM
JimK-NY wrote:
Thanks, I think this suggestion on a vented cap is the way to go. Just a pinhole should be enough to handle temperature and pressure changes.
Jan-13-2023 09:22 AM
otrfun wrote:
We've been securing our 2 gal container with velcro straps on our rear ladder for years. As you mentioned previously, with the OEM spout stored inside the container it will eventually leak gas everywhere. We travel with the spout on the outside and secure the end with a pin-hole, vented cap. It's never leaked, expanded or collapsed even in temps as high as 105 deg or temps as low as 0f. Also, we never fill above the "fill" line on the side of the container.
Jan-13-2023 07:15 AM
theoldwizard1 wrote:Grit dog wrote:
Also for your small qtys non ethanol is not expensive ...
Not where I live !
E10 is NOT as bad as people make out ! Just don't store it more than 2-4 weeks and make sure to run the carburetor dry after every use.
Jan-13-2023 06:34 AM
Not where I live !
Jan-13-2023 03:54 AM
Jan-12-2023 06:12 AM
JimK-NY wrote:We've been securing our 2 gal container with velcro straps on our rear ladder for years. As you mentioned previously, with the OEM spout stored inside the container it will eventually leak gas everywhere. We travel with the spout on the outside and secure the end with a pin-hole, vented cap. It's never leaked, expanded or collapsed even in temps as high as 105 deg or temps as low as 0f. Also, we never fill above the "fill" line on the side of the container.
. . . I believe what I need is a better gas tank and mount it on the ladder . . .
Jan-05-2023 06:36 PM
Jan-05-2023 06:25 PM
Jan-04-2023 07:54 AM
Jan-04-2023 07:53 AM
Jan-04-2023 06:31 AM
Jan-04-2023 05:53 AM
Jan-04-2023 05:50 AM
JimK-NY wrote:
Thanks for the suggestions. I believe what I need is a better gas tank and mount it on the ladder. I could not find details on the Mountain Addiction possibilities. Rotopax initially looked really good until I read about the need to vent the can every 10 degree temp change or 1000 ft change in elevation.
Jan-03-2023 04:55 PM
