โDec-29-2020 11:56 AM
โDec-30-2020 03:23 PM
โDec-30-2020 03:12 PM
Sjm9911 wrote:ls1mike wrote:Sjm9911 wrote:
It will be a ton of an improvement over the 150. Lots of power. My TT is light so maybe 5400 loaded and i load up the bed of the truck. It has power to pass and stop. Like a lot of it. I have no problem now passing big rigs on big inclines. Before with the 2012 gmc i had issues going up large inclines. I had to pull onto the slow down lanes for the trucks. Now , i can honestly say i pull faster, 70 ish. Where before was 60 ish. With 0 problems. Plus is more cab room, more bed room ( a lot). I like the back up camera for hitching up, and when your close you swap to hitch veiw to get it lined up perfectly. Also, it automatically puts the ellectric e break on so you dont roll out from the hitch. Other great options, auto scolls the lights for a pre check. No more needing a second person or a weight to hold the break down in the truck. I like it for towing a lot. Especially with a smaller trailor. It had a good upper limit on tow weights also. Longest trip this year was nj to lake george, so 4 hours. Also did a few trips to pa, through the water gap, big inclines. Mirrors are better to see out of hitched up. Only con is not great gas millage, and its big. So its my DD. Its fast.
Was the 2012 a 6.0? I have a 17 and tow all over out West(Oregon, Washington, Idaho and Montana) and that has not been my experience.
I like the 6.6 but for me it wasn't enough difference to go back into payments. I am waiting to see if you can get it with 4.10s and a few more speeds.
No it was a 1500 5.6 , max tow. I think it had to do a bit with the emissions stuff. Your a lot newer also, so 5 years will make a diffence. It had the auto cylinder thing. So by the time you stepped on the gas and the slight time delay in the relays it was too late( just assumtions on that reading after the fact). I did use it to tow to disney and back. It towed fine, just got squirrely at 60 or 65 mph. That atually depending on the road type. And it got pushed around too much by the 18 wheelers blowing past me. Addtionally the small gas tank made the disney trip way longer then it needed to be. And accelerating to get on and off the hyway because of lower power wasnt fun eaither. Could it tow. Yes. Was it fun. Hell no.
โDec-30-2020 03:06 PM
โDec-30-2020 03:03 PM
โDec-30-2020 02:43 PM
โDec-30-2020 02:33 PM
RobWNY wrote:ksss wrote:
I have a lightly loaded '20 LTZ. Doesnt have the multi camera system (but I wish it did).
Be careful what you wish for. I have a very loaded 2020 LT. It does have the multi camera "system". I put that in quotes because you have to buy the extra cameras for placement on your RV which I opted not to do. The backup camera on GM trucks that come with the system, is different than the standard backup camera. They come with a wide angle camera. It's pretty much useless as a backup camera under normal backing conditions. Everything is distorted and the truck sensors beep all the time because it thinks I'm going to hit something that I'm not even close to. The view when backing up while the wheels are turned makes the distorted view in the photo 10X worse. I've had two dealerships tell me it's normal and nothing can be done to correct the problem.
โDec-30-2020 08:55 AM
โDec-30-2020 08:04 AM
โDec-30-2020 07:11 AM
โDec-30-2020 05:37 AM
โDec-29-2020 02:13 PM
โDec-29-2020 12:20 PM
