Grand Design Imagine 3150BH
Galena
Does anyone tow a Grand Design Imagine 3150BH with a late model, 2017, 1/2 ton truck. It looks like it may be on the border with load capability, not pulling?
๐Ÿ™‚
6 REPLIES 6
drsteve
That is too much trailer for a half ton truck.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
ScottG
Way, way, waaay too little truck.
mbopp
Seriously undertrucked, especially if your 1/2-ton is a crew cab & you're hauling a family.
2019 F250 XLT Supercab
Just DW & me......
bailer6334
I have a Grand Design 2150RB and the published tongue weight is 485lbs. My actual tongue weight is 750lbs (2 propane tanks, 2 batteries & WDH). So the published weight is misleading. Can you pull it "YES". Will you be over on 1 or more rating for your truck most likely. Will it be a enjoyable towing experience? Probable NOT.
Remember its 35ft 11inches long!
2017 Grand Design Imagine 2150RB
2016 Chevy 2500HD LT 6.6L DMAX 4WD
Equalizer 4 Point WDH
DinTulsa
You will be over a rating somewhere for sure, most likely payload or receive hitch rating. With the right setup hitch wise you can probably tow it safely, but I would imagine that there will be some white knuckle moments. That's a lot of trailer for a half ton, what gears does your truck have?
APT
I estimate that's over 8500 pounds loaded for al long weekend with 1100 pounds of TW. Few half tons can handle that and not exceed one rating or another with a family in the cab. Payload, rear axle, and receiver ratings should be verified in addition to tow rating.
2017 Subaru Outback 3.6R
