Happijac issue
mattyj
I’m trying to get the remote for these to work with the receiver , but No! I can get all the jacks work at once and the rear to work ok , but the fronts don’t work, I have tried connecting cable to the receiver from the remote, and to reprogram the remote, but they still don’t work, right. It’s also very difficult to find someone who will service these Jacks . Can anybody give me some help?? Thanks
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
32 REPLIES 32
opnspaces
Navigator II
Navigator II
mattyj wrote:
opnspaces wrote:
What do you mean by the jacks behaved worse after you swapped the wires. Can you help someone like me visualize what is happening?
Originally as reported
All jacks work at once. That makes sense to me
The rear jacks work ok. Does that mean you can extend each rear jack individually or just extend them as a pair?
The Fronts
don't work. Yep easy to understand.
You then tried swapping the wires and said it got worse. Can you describe what happened? Did you suddenly have no jacks? Did all the jacks except one rear stop working? If so which jack? Did a front jack ever try to work? If so which jack?
The All JACKS button Only the left rear goes opposite and Right rear goes opposite , the other jacks do not work at all.
LEFT FRONT up button goes down and the left front down button nothing happens
LEFT REAR down button goes up and the up button nothing moves
RIGHT FRONT up and down buttons, nothing moves
RIGHT REAR. up button does not work and down button goes up .
I hope this isn’t too confusing.
Nope it's actually clear when I space it all out as above. But yes I can see why you said it's worse. Going back to your original post where you say ALL Jacks work at once really sounds like the jacks and the controller are all working and as you suspected the remote is faulty.
HMS_Beagle
Did the remote come with the controller board? It sounds to me like the encoding of the remote does not match the controller board. Different hardware revisions, different software revisions, or the like. If you bought them separately, I'd think you'd have to check with Happijac to see if they are compatible, probably need pn or serial numbers for each to tell.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
mattyj
I have all the wiring connected as per Happijac website
mattyj
The Fronts
The All JACKS button Only the left rear goes opposite and Right rear goes opposite , the other jacks do not work at all. LEFT FRONT up button goes down and the left front down button nothing happens LEFT REAR down button goes up and the up button nothing moves RIGHT FRONT up and down buttons, nothing moves RIGHT REAR. up button does not work and down button goes up . I hope this isn’t too confusing.
opnspaces
Navigator II
Navigator II
The Fronts don't work. Yep easy to understand.
mattyj
mattyj wrote:
3 tons wrote:
I had that problem and when looking at the controller :?board discovered that in the lower right hand corner, a wire lug had come loose from the board…I reinserted it and all was well…
3 tons
I’ll go try that right now, thanks
that wire lug was tight. No luck
mattyj
3 tons wrote:
I had that problem and when looking at the controller board discovered that in the lower right hand corner, a wire lug had come loose from the board…I reinserted it and all was well…
3 tons
3_tons
3 tons
mattyj
SoonDockin wrote:
My camper came with two remotes. One wired and the other wireless. Is it possible you have a second remote?
I only have one remote, I ordered one on eBay and the numbers in the photo in the ad matched my remote, but of course they sent the wrong one and now when I try to print the return label they sent me to return the wrong one I can’t get it to print ??????????
mattyj
StirCrazy wrote:
mattyj wrote:
mkirsch wrote:
People are ignoring that ALL THE JACKS WILL WORK AT ONCE.
That means the jacks are getting power. That means the jacks are NOT stuck. That means the jacks are getting a signal. That means the lever on the side of the jacks are in the correct position.
The problem is either in the remote, or in the jack controller in the camper. The problem is electronic, and for most of us the only thing we can do is replace things until it starts working again.
It would be interesting if you could swap the wires from the front jacks to the rear jacks, and verify that the problem follows the wiring, not the jacks.
I will go look to see if I can swap the wires from the front jacks to the rear jacks. I’m not sure if they will reach.
swap them at the control board. just plug the fronts into the bak sockets and the other way for the backs
I swapped all the wires on the control board, and it made the jacks behave worse than before so I just put them back to the original position
SoonDockin
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
StirCrazy
Moderator
Moderator
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
mattyj
mkirsch
Nomad II
Nomad II
mattyj
B-n-B wrote:
Make sure the lever on side of the jack is in the UP position. Easy to overlook.
https://www.happijac.com/images/pdfs/10keywired.pdf
yes, they are all in the up position do
