Hayes Plug and Play Elect Sway control
cruz-in
Hi Team,
IMHO, this is an impressive devise. Plug and play electronic sway control.
Hayes Electronic Plug and Play Sway Control
Would not use it as my primary sway control, however might be cheap insurance.
Chatted with company about the brochure saying it was for use without wd. They say no worries using it with WD as long as you can find a place to mount it properly on the A-frame.
Just passing this on for info...never used the device so cannot comment on it....
2011 Monaco Vesta
Interesting Coach
This particular one was the prototype.
33 REPLIES 33
hohenwald48
Jayco Sway Recall
They are removing from all Jayco units.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Rbertalotto
There is a full review in this months Trailer Life......
Some of the comments by the "experts" just crack me up! Disc brakes are better for sway control than electronics? Manual control is all you need? Just set trailer up properly and you'll "never" have sway!
I guess we should disconnect ABS, fuel injection, dual diagonal braking, traction control and all other electronic devices as they are simply not needed.
This is a great additional safety feature that for $212 could save your life.....but more importantly, could save MY life if the trailer fish tails in front of me!
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
mtntop1
It uses the same principle as independent braking on aircraft.
cruz-in
Concur on shocks and discuss brakes being great. But at $200 cost to Trailer manufacturers, seems to make lots of sense to install in a new build trailer.. Seems to me this is lots of safety for the $s..
2011 Monaco Vesta
Interesting Coach
4X4Dodger
To my mind if you want your trailer to handle better your money is much better spent putting on Shocks and disc brakes. That will do more than any "Sway Control" you could buy.
cruz-in
went ahead and ordered the Tuson Sway Control for $344...I will keep all appraised of how the install and checkout tow goes...
2011 Monaco Vesta
Interesting Coach
cruz-in
hohenwald48 wrote:
I wonder if there are any real statistics regarding the number of accidents due to excessive sway?
IMHO, the beauty of these systems is not in a classic excessive sway situation (although they do great there) but an evasive maneuver. During an evasive maneuver, the system would keep the trailer tracking behind you. Allowing you the most control to avoid whatever you are evading...
2011 Monaco Vesta
Interesting Coach
hohenwald48
cruz-in
I applaud Jayco for putting them on all trailers. Makes the road safer for all of us.
I also am very positive. For a cost of $200 (and I am sure much, much less for Trailer manufacturers), This is a very inexpensive addition for the good it does....
2011 Monaco Vesta
Interesting Coach
fla-gypsy
As with any new device or technology some will not pan out and there will always be a chorus of those who swear it can't work but given a little time it will likely become the gold standard for sway control. I will watch with some interest to see how this one does.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
Lynnmor
cruz-in wrote:
Lynnmor wrote:
GaryWT wrote:
My truck has build in sway that will apply brakes if needed but I like the sway that is part of my hitch.
The device in question can select right or left trailer brakes as needed, your truck cannot.
I don't believe that is the case with this device. As it is plugged into the 7 pin connector it only has access to the brake wire which activates all trailer brakes.
Now the dexter electronic anti sway control (that is hardwired into the right and left brake wire), operates as you describe with activating left or right trailer brakes as required.
I'm sorry, you are correct. I first thought that it was just another copy of the Tuson system.
cruz-in
Caravan World Review of Dexter Sway Control...
2011 Monaco Vesta
Interesting Coach
4X4Dodger
beemerphile1 wrote:
It applies the trailer brakes when sway is detected which is the same thing the manual slide on the controller is used for.
If it malfunctions even a tiny amount the trailer brakes will be off and on constantly increasing fuel consumption and wearing out the trailer brakes.
No thanks, it is a solution looking for a problem.
I agree 100%. As I have repeated here many times, "Sway" is driver induced and if you load, maintain and DRIVE your trailer correctly you will never be bothered by "Sway"
Another useless product.
cruz-in
First video I have found that gives a good technical description of how the Dexter/Tuscon Electronic Sway control works...
Description of How Tuscon (now Dexter) Electronic Sway control works...
2011 Monaco Vesta
Interesting Coach
