How do I haul a TC while still having the 5th wheel rails?
Mote
We are in the process of buying a 2001 Lance TC. I currently have the standard reese 5th wheel rails in the bed of my truck. We plan on keeping both campers for another year or two.
Those of you who have both, what do you do to haul the TC ?
thanks,
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
10 REPLIES 10
Mote
I pulled the bed liner pulled out tonight. The distance between the wheel wells with the bedliner is exactly the same as the width of the camper. So, the bedliner had to go.
I then laid a level across the 5th wheel rails and took a measurement for the how thick of foam board I'll need. It's 1.5" so I'll go for the 2" foam board for a safety margain.
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
dodgerdog
I have the post style plate in the back of my truck I just cut out around the plate and spar varnished the 4 x 8 sheet of plywood from home depot... Works great....
Mike C.
Mote
Thanks for all the ideas. I'll probably try the foam board route. Looking forward to our first truck camper trip.
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
River_Sand
fuelhauler wrote:
When I still had my 5vr I used owens & corning foam board to set the camper on. Get the high density 2" thick board. Worked fine for me for years & easy to remove when not needed. Oh & my camper weighed 4000 loaded.
I use the same only in 3/4" 4x8 sheet. The SS hitch only leaves 4 "pucks" in the bed when the hitch is out. The foam board compresses nicely around the "pucks" and leaves a nice flat surface for the camper.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex ๐Ÿ˜„
01 HighJumper SandSprite 3 Dune Buggy :E
Fish__n___Grits
My last TC required a 2" spacer to clear the cab lights. I made a 1-1/2" x 1-1/2" frame and put 1/2" plywood on it. It keeps this camper clear of the 5th wheel rails. It has worked fine since "02. I also use it under the camper on its dolly when off the truck.
Billy & Dale
'99 F350 DRW Superduty
'02 Lance 1161
Salli the "Schnoodle"
fuelhauler
2005 Dodge q/c 4x4 dually six speed pac brake
2014 Arctic Fox 990
2014 16' smokercraft
sue_t
2x4 frame that fits the bottom of the truck box with an opening for the hitch rails.
The long side of the 2x4 frame gives the added benefit of being a reference while loading the camper. Makes it easier to see your alignment while backing under the camper.
sue t.
Pictures from our many RV Adventures to Yukon & Alaska from Vancouver Island. Now we live in Yukon!
jimh406
You could also sell your current hitch and switch to a B&W turnover hitch type.
camperpaul
Make a framework with 2X4 treated lumber to fit the bed with an opening for the 5er hitch.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
Super_Dave
Plywood to the depth of the rails and a cut out.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
