Feb-23-2018 09:45 AM
Jul-20-2018 12:35 PM
Feb-25-2018 08:51 AM
Feb-25-2018 08:36 AM
SoundGuy wrote:Gdetrailer wrote:
... but Soundguys photos CAN BE CONSIDERED COMPLETELY NORMAL FOR FIBERGLASS LAMINATION.
It IS the "nature of the beast", sometimes the bond holds and sometimes the bond doesn't.. Fiberglass has a large expansion/contraction ratio..
Perhaps, but exposure to the environment must also have a lot to do with it. That delamination I had on our Spree was only on the curb side of the trailer which was exposed to the harsh sun all day, every day, while parked here at the house during the season while the street side which showed no signs of delamination at all was always sitting in shade. Our current Coachmen is now 5 yrs old and sits in the exact same location on the driveway yet shows no signs of delamination anywhere so I can only conclude it's due to improved bonding methods used to assemble it's sidewalls.
Feb-25-2018 06:50 AM
Feb-24-2018 11:45 AM
SoundGuy wrote:SidecarFlip wrote:
I bet both of you have water damage UNDER the siding. Filon don't delam for no reason.bbells wrote:
I wish it was that easy. There was no sign of any water damage when I took the windows off, on the inside or on the outside. And the luan when I shoved a tiny camera down by the window showed it was separating from the siding, but none of the rotting stuff that water causes. Plus, the entire trailer was caulked and sealed a few months after I got it (windows removed, sealed, etc). The bubbles only expand in the winter. I have a hard time believing water damage with no sign of water damage could have this big effect starting at 6 months and in just 2 years.But, it could be invisible water damage. But, if it can do this with no sign it would have to be a mfr defect.
BTDT myself and wouldn't agree this is necessarily because of water damage. My own 2008 K-Z Spree 240BH-LX which we purchased new began to delaminate on the curb side about 3 years into ownership for no apparent reason. Careful inspection showed absolutely no signs of water leakage anywhere yet the curb side wall would crease outward in several locations, the hotter it was the worse it looked and in cold weather was hardly noticeable at all.
This was on the side that took the full brunt of the summer sun while the trailer was parked here at the house, the street side which was in shade all the time never delaminated at all. My conclusion was the adhesive inside the wall just let go and there was nothing I could do about it as I wasn't going to dump $1000s into repair that may or may not make it look any better. We eventually sold the trailer several years later, not because of the delamination, but because we no longer required a trailer with bunk beds. JMO, but I'd suggest you just enjoy camping with your trailer as it is and not worry about this delaminnation, particularly if you're convinced it's not a water intrusion issue.
Feb-24-2018 10:48 AM
keymastr wrote:
Pretty sure the attorney generals office might say different about that. The warranty is provided to the original purchaser not the dealer. If it sits on the lot for 2 years it still has the full factory warranty.
Feb-24-2018 10:44 AM
Feb-24-2018 10:41 AM
Feb-24-2018 09:04 AM
I bet both of you have water damage UNDER the siding. Filon don't delam for no reason.goducks10 wrote:
Thats exactly what the MFG would tell you too.
The MFG isn't obligated to tell the OP anything :R ... he has 2014 model so even though he earlier said "it is only a couple years old" the fact is it's well over 4 years old and this spring will be considered 5 years old once 2019 models start rolling off the production lines. With a trailer of this age delaminating no manufacturer will hold any responsibility at all, won't care at all - it's a case of too bad, so sad. 😞
Feb-24-2018 08:43 AM
Feb-24-2018 08:33 AM
Feb-24-2018 06:29 AM
Feb-24-2018 04:42 AM
SidecarFlip wrote:
That isn't bad really. I would have ignored that little speed bump.
Feb-24-2018 04:08 AM
