โJun-25-2013 08:11 PM
โJun-30-2013 06:29 AM
โJun-30-2013 12:26 AM
โJun-29-2013 08:20 PM
wintersun wrote:
I would not look at it so much as age as the tow capacity of the truck when new and the type of use it has had over its miles of driving. Chevy for example switched to all wheel disc brakes in 1999 and a pre-1999 truck or SUV would be a lot less desireable regardless of the mileage. Some engines are a lot more reliable and same applies to transmissions. I would pass on a TV with a 4-speed transmission and want a newer vehicle with a 5 or 6 speed transmission.
Lots of used trucks, in particular DRW ones with a regular cab, that have been full time work trucks. These get abused a lot more by their drivers and maintenance is less likely to happen on a regular basis. With as much as 100% hard use these trucks are not a good choice for a TV regardless of what shows on the odometer.
Hose, belts, alternators, AC compressors, ball joints, rotors, shocks, radiators, springs, etc. can all be replaced and in some cases upgraded to keep a vehicle as good or better than new. What an older truck or SUV may lack is air bags for the driver and passengers or ABS. The airbags are important to me and I would not buy a vehicle that did not have them.
โJun-29-2013 08:13 AM
โJun-29-2013 07:13 AM
โJun-29-2013 06:59 AM
โJun-28-2013 04:54 PM
BigToe wrote:
My next tow rig, after I wrangle, wring, or wreck every last drop of life out the two that I have, will be at least 50 years old when I start the retro restoration. I'm thinking about a Diamond T, or Mack... something curvy and nostalgic. Age is just a number.
โJun-28-2013 04:09 PM
โJun-27-2013 07:23 PM
โJun-27-2013 06:01 PM
chorbelt wrote:cdar wrote:
How old is too old and the same for mileage? This is a third vehicle that's only going to see weekend and towing duties. I'm fairly comfortable with a good older tv but then how do you know? Im not as much a gear head anymore so I don't know what trouble spots to look for for a particular brand. My next tv needs to be trustworthy enough to haul the family up and down the east coast (Maine - SC).
I don't think that there is anything inherently "too old". Here in the Puget Sound area of the NW, they don't use salt frequently in the winter, so body and frame rust/rot isn't a problem. Mileage can be more subjective, because it really is a******shoot on what maintenance was done. I've been lucky with visual inspections; ie if it looks beat on, it more than likely was. If it looks well taken care of, it probably was.
I've got the best tow vehicle for me. The 7.3 is well known to be reliable, with a couple of exceptions; turbo up-pipes and CPS (cam position sensor) being most common problems. The 5-speed holds up well once the dual-mass flywheel is replaced. Crew-cab long bed means the kids have room to bring as much stuff as they want. Best thing is that it's been paid for since 2000. I'm sure there are Dodge and Chevy guys out there who feel the same about their TV's.
Whatever brand or direction you choose to go, for a used vehicle, I'd definitely plan on budgeting some extra $$ for brakes, ball joints & steering bushings, flush all the fluids, replacing all the belts and driven accessories on the engine; power-steering pump, alternator. Don't forget that you might need a new hitch or trailer wiring/brake controller as well. Good luck with your search, for me that was half the fun!
โJun-27-2013 05:44 PM
โJun-26-2013 01:20 PM
โJun-26-2013 12:27 PM
โJun-25-2013 09:49 PM
