โNov-05-2017 08:59 PM
โNov-08-2017 08:44 AM
โNov-08-2017 07:59 AM
โNov-07-2017 06:54 PM
โNov-07-2017 04:40 PM
keymastr wrote:
Service writer just called, they tried to start it to diagnose the issue and it is locked up solid. Looks like I will not be going winter camping as they are backed up about a month before they can start on it. Oh well, gives me time to plan our spring southwest tour.
โNov-07-2017 03:19 PM
โNov-07-2017 02:25 PM
Lessmore wrote:All I could afford wrote:
My 2013 6.8 L V10 at work swallowed a valve when it was 2 years old. Was just a few hundred miles over warrantee and Ford refused any goodwill offer. We installed a new ford crate motor, and not even 2 years later that one also swallowed a valve.
Closer inspection revealed that one of the rocker arms had side to side play, and caused it to damage the valve retaining mechanism. Third motor is so far so good. We run our work trucks hard at my job, but use Motorcraft semi synthetic and Motorcraft filters once a month.
On a sidenote, our 2009 Ram 6.7 Cummins just put a rod through the block toward the back on the driver side, but it ran 490,000 miles in those 8 years!
Does your company still buy Ford trucks after this pattern valve issue and Ford's response to provide some financial support ? Not trying to start a range war, just curious as we have considered buying a new Ford vehicle.
โNov-07-2017 01:57 PM
โNov-07-2017 01:40 PM
โNov-06-2017 06:17 PM
โNov-06-2017 03:58 PM
โNov-06-2017 03:44 PM
keymastr wrote:
My 2016 F250 decided to blow up yesterday so I guess I will see how good Fords warranty coverage is. It has less than 15,000 miles on it. was taking a couple things to my work and had just pulled in to the parking lot and it started running rough and knocking a bit.Barely enough power to park it. I don't think it was a rod knock, not a heavy enough knock. More like the valve train disintegrated. I guess I will find out soon enough.
Any tips for dealing with Ford over this? I would hope they provide a loaner.
โNov-06-2017 02:03 PM
โNov-06-2017 01:45 PM
โNov-06-2017 01:28 PM
โNov-06-2017 10:33 AM
