โOct-08-2019 08:44 PM
โOct-13-2019 10:29 AM
โOct-12-2019 09:26 AM
โOct-09-2019 10:25 PM
work2much wrote:mgrady619 wrote:
I've read all of the "can a 1/2 ton carry a camper" conversations, no desire to poke that with a stick. I have a twist on the question:
Assume I get the camper into location, either empty and within weight rating, or renting a 3/4-full ton to get it there, then move into it as the increasingly common Silicone Valley streetside apartment, can I load it down at that point? Do the stilts, or whatever the proper lingo is, provide enough support to take the load off the axles? Obviously braking/handling are no longer a concern, but how about suspension, tires, axle?
Thanks in advance
It sounds like there will be a truck under the camper one way or another? Truck axles/tires etc. are rated for driving where load stresses are substantially intensified. When the truck is parked you could substantially go over any GVWR/GAWR numbers without having to worry about damaging the truck. On a practical note though parking along a road where you may be required to move it would make sense to have a suitable truck to drive safely vs. being towed.
โOct-09-2019 01:32 PM
โOct-09-2019 10:26 AM
mgrady619 wrote:
... I would just do a standard shell but I have an offer on a free slide in camper from a wealthy relative.
โOct-09-2019 10:09 AM
Thanks in advance
โOct-09-2019 09:41 AM
โOct-09-2019 07:32 AM
โOct-09-2019 07:03 AM
โOct-09-2019 07:01 AM
โOct-09-2019 07:00 AM
โOct-09-2019 06:31 AM
โOct-09-2019 03:43 AM
โOct-08-2019 10:40 PM
