Installed new Norcold board and fridge still won't work
1kennyOG
Board was fried on the N611/N811 SO I installed a new one. Cost me around $300 CAD.
Now the fridge is blinking both lights faintly. Certainly not as bright as before.
I do not hear the propane trying to light.
Fridge does not work on gas or electric.
Any advice is appreciated.
2006 Kodiak Hybrid.
thanks
20 REPLIES 20
hohenwald48
donn0128 wrote:
Should have bought a Dinosaur board.
Are suggesting the new board he bought is faulty too?
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
1kennyOG
good info-
I turned the job over to my friend who is a licensed electrician.
JimHanus
I know this is an old thread, but here is my experience. My TT had a bad outlet that the fridge was plugged into. Not bad as in not working, just dampness would get into it in heavy rains (not obvious water) and trip the GFCI. The fridge is somehow wired through the GFCI which is located in the bathroom (not a real obvious link), so even on 12V only (we only boondock), the fridge wouldn't light with the GFCI tripped. Replaced the fridge outlet and all is fine. Also replaced the GFCI with one that has a green led when good and switches to a red led when tripped. Also wrote on the fridge outlet as a reminder that it was connected to the GFCI. This was the second TT I've had with a fridge not working due to a GFCI being tripped. Slow learner I guess ๐Ÿ™‚
hohenwald48
1kennyOG wrote:
Thanks for the help.
Did the trouble shooting many days ago.
Old-Biscuit wrote:
Open link I posted to manual and follow the troubleshooting .....OR NOT!
And when you went thru the troubleshooting flow chart posted by OB where did you end up?
1kennyOG
Old-Biscuit
Mont_G_J
Bad or no ground wire to circuit board.
Mandalay_Parr
1kennyOG wrote:
would there still be low voltage when plugged into 30amps?
thanks
westend wrote:
I would suggest putting a meter on the battery and a meter on the circuit board to measure voltage. The dim lights are an indicator of low voltage.
Could be. Really need to trace with a meter.
Jerry Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
budwich
X2... you need to understand what voltages are present at the control board... along with checking its grounding.
1kennyOG
I did
donn0128 wrote:
Should have bought a Dinosaur board. Gas on? Gas lines purged? Good 12VDC? 120VAC at the outlet?
1kennyOG
thanks
1kennyOG
Yep, tried the drive too ๐Ÿ™‚
bobndot
sounds crazy, but take it for a drive , I had to do that in order to free up a line.
http://www.forestriverforums.com/forums/f113/dometic-fridge-not-working-at-all-29566.html
westend
'03 F-250 4x4 CC
