โJul-22-2016 12:36 PM
โJul-28-2016 10:32 AM
CavemanCharlie wrote:TenOC wrote:MitchF150 wrote:
This is the same jack I've had in my truck for basically 'forever'.. I don't even remember how old it is, but I've had it for a loooong time..
Mitch
Placing the bottle jack as in the photo can cause a weak spot in the frame that can cause the frame to fail. Be sure to place wood or metal to spread the force out over more of the frame. Too much weight on the small 1 inch jack. Don't ask how I know, but you can find a good used TT in NM with a broken frame if you want to use it as . . :M . . "do not move" trailer.
That's what I was thinking. Not the correct place to put a jack.
โJul-27-2016 09:58 PM
โJul-26-2016 03:14 PM
โJul-26-2016 02:57 PM
โJul-26-2016 11:48 AM
fla-gypsy wrote:
6 ton bottle jack with wood blocks to achieve needed height while on the road. At home I use a "Trailer Aid" device
โJul-26-2016 09:51 AM
โJul-26-2016 09:47 AM
โJul-26-2016 09:17 AM
He has torsion axles, not springs. Where would you suggest he position the jack?
โJul-26-2016 08:01 AM
โJul-26-2016 06:29 AM
โJul-25-2016 07:12 PM
Mitch
โJul-25-2016 12:02 PM
Mitch
โJul-25-2016 11:55 AM
jasoncw wrote:
Do you have a dual axle TT? And are they they close together or spread apart? If they are close, you can just ride up on a few leveling blocks, and it will pop the other tire off the ground. If you want to spend the money on a tool specifically for it instead of using blocks, you can use a Trailer-Aid.
โJul-25-2016 11:17 AM
