Jun-22-2013 08:14 AM
Jun-25-2013 01:05 PM
Grit dog wrote:midnightsadie wrote:
not throwing a stone but nobody should be towing at 70 plus mph , your puting every one in danger . and yes you,ll get much better mpg at 65 even better at 60.slow down cheat a oil guru out of some money.
Really?
Wieght police and now speed police!
To the OP, it will suck gas, period.
Had several Gen 2 Rams with the 360 V8. Good bullet proof motor, but they will work just as hard as any gasser. You won't see an appreciable mpg gain with any gas powered rig.
Jun-25-2013 12:59 PM
Jun-25-2013 04:26 AM
Jun-25-2013 04:08 AM
Jun-25-2013 01:19 AM
Jun-24-2013 11:27 PM
Jun-24-2013 07:54 PM
lancekeys wrote:
Well, I just filled up my tank after picking up the trailer and one camping trip. I drove a total of 122 miles and got 6.5 miles per gallon. When I pulled the trailer home, I was really impressed with how well my truck pulled it and how I had all the power I needed. Well no wonder I was making a
Jun-24-2013 07:09 PM
NC Hauler wrote:4x4ord wrote:Goose2448 wrote:
I have found myself towing 20K trailers at 90+. Easy to do with no cruise. Yes I use that when towing on the straight and flat. My truck gets better milage at 79 vs 65. You have to find the sweet spot for your truck. Mine is right at 1900 rpms. That means when towing, I drop to 5th at 66 mph and its just about perfect. I also try to stay with the flow of traffic, say 5 under. Speed limit is 70 all around here so it works out.
Quick story, I used to work for a company that had a 05 3500 DRW 6.0 gas and a 06 3500 DRW 4x4 LBZ. They towed the same trailers with the same weight on them. The gasser saw between 3-5 mpgs loaded while the LBZ saw 12ish. It also didnt struggle to get going or feel like there was too much weight behind it. We scalled 35K Daily. Plus a Diesel is more fun to play with, so you may spend a little more out of pocket, but the smile it will put on your face is priceless.
I can believe someone getting up to 90 mph while towing if they're not paying attention but I would need to see it before I am going to believe that any truck will get better mileage at 79 mph than 65 mph .
Agree, I find it hard to believe someone would get better mpg running at almost 80 mph versus 65....can't buy into that one, makes no sense.
Jun-24-2013 06:34 PM
Jun-24-2013 06:20 PM
Jun-24-2013 06:17 AM
Jun-24-2013 06:10 AM
lancekeys wrote:
What an interesting run of replies! The speed limit was 75 on I-30 where I was running. The trucks however stay around 65, so I will hang with them next time. My long term plan is to drop a 12 or 24 valve cummins in when the 360 bites the dust. Hopefully this will be a long time from now.
Jun-24-2013 06:07 AM
thomasmnile wrote:Gdetrailer wrote:
While some folks have voiced an opinion about 70 being too fast, I would tend to disagree with that statement. Towing at 60 or even 65 on most interstates makes YOU A DANGEROUS TARGET.
Especially true on roads with 70 MPH limits posted, folks are often driving 75-80 MPH and may not notice in time a vehicle which is 10 MPH or more below the limit. Those would be the trailers with blown tires I catch up to driving 60 mph after they blew by me at 75 or 80. Unless the speed limit is 75-80 THEY are breaking the law!
Driving anything too far below the speed limit can get you fined since you become a safety hazard to other motorists trying to get around you or even not noticing you are going slower than the rest of the pack. Really? Where's that? Minimum speed on most Interstates I'm aware of is 45 mph. Florida passed a law this year that can get you fined if you're driving less than the speed limit in the left or center lane on an Interstate. That was enacted to move slower traffic to the right lane.
If you are scared to drive at 65-70 then perhaps you should choose a slower and more scenic route. Scared? The tires on my trailer are speed rated to 65 mph. Somebody smarter than me determined that so I think I'll abide by the manufacturer's recommendation. Like Dirty Harry once said, "A man's got to know his limitations". And from what I've seen on the road, there's a lot o' folks that don't. Some of them even pontificate on forums like this espousing hauling the mail with a multi-ton RV/truck combo that they may or may not be capable of handling in an emergency.....
Jun-24-2013 05:23 AM
Jun-23-2013 07:56 PM
