โDec-04-2018 06:11 AM
โDec-24-2018 05:01 PM
โDec-13-2018 08:28 AM
โDec-12-2018 09:56 PM
โDec-12-2018 07:22 PM
srt20 wrote:
I didnt read this whole thing, but have you pulled the starter yet? Brushes are probably worn.
โDec-12-2018 07:20 PM
โDec-12-2018 03:19 PM
spoon059 wrote:
You've already answered your own question. Change your dead battery and it'll likely work fine.
โDec-12-2018 02:59 PM
Picinisco wrote:
If you look at the first post, this was the question. I have a block heater, but what do others use when boondocking.
Picinisco wrote:
Battery driver side 650CCA reads 690CCA and 3.5 ohms. Passanger side 650CCA reads 190CCA and 13.5 ohms.
โDec-12-2018 09:51 AM
โDec-12-2018 08:47 AM
โDec-12-2018 07:54 AM
ppine wrote:
Never owned a Cummins engine, but they always seem to have block heaters on them. Living in Wyoming we learned what works. Number one diesel, synthetic oil, plug in at night. Keep your batteries up. I love diesels.
โDec-12-2018 07:46 AM
โDec-10-2018 09:00 PM
ppine wrote:
Air filter should not be a problem at all.
The first thin I would check after the battery and starter, would be glow plugs. Any diesel should start easily down to around 25 degrees.
โDec-10-2018 03:22 PM
memtb wrote:
Depending upon the age of the โgoodโ battery.....you really should replace in pairs! I know it hurts the wallet a bit....I just (6 weeks ago) replaced six (6) in our 5th. wheel. All were old ....but only one โtrulyโ bad.
โDec-10-2018 02:56 PM
