โAug-07-2020 10:50 AM
โAug-13-2020 08:00 AM
โAug-13-2020 02:53 AM
โAug-12-2020 06:33 PM
โAug-12-2020 02:24 PM
โAug-09-2020 09:04 AM
โAug-08-2020 10:49 PM
โAug-07-2020 07:10 PM
โAug-07-2020 06:53 PM
โAug-07-2020 05:46 PM
โAug-07-2020 04:32 PM
JIMNLIN wrote:The Truck I'm looking at is a 2020 Big Horn 3500 6.7 HO cummins Mega Cab 4x4 SRW. GVWR should be 12,300. Payload should be around 4K lbs.
A 4k payload will have to go on both axles as its a GVWR based payload.
The 3500 SRW Ram has a 7000 rawr. These trucks are heavy and rear axle may weigh 3400-3500 lbs which leaves around 3500-3600 lbs in the bed.
This means a upgrade in wheels or tires or rear suspension as they all need to meet or exceed the load you place in the bed from a TC.
Measurements are so close and you have the TC I would drop by a Ram dealer and take some actual measurements.
Someone may have the same combo so stay tuned.
โAug-07-2020 04:17 PM
โAug-07-2020 04:12 PM
โAug-07-2020 03:57 PM
โAug-07-2020 03:24 PM
