Larger Windows in Bigfoot Campers?
adamis
Nomad II
Nomad II
A friend just bought an adventurer truck camper and I have to say, I am quite impressed. I really like the forward bath across from the fridge layout. More privacy in the bedroom and it really opens up the rest of the camper with the dinette across from the gally. Overall very nicely done camper.
One of the things that stood out to me was the larger Windows in the kitchen and dinette that I really liked. I think they must have been 2" or 3" taller than my Bigfoot windows. To the point of my post, is there anything preventing one from installing larger Windows in the Bigfoots? Obviously it would require cutting of fiberglass to do it but are there any structural reasons one could not do this?
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
9 REPLIES 9
Z-Peller
On a side note, how much privacy do you need in the bed area of a truck camper?
How many people are in there?!!
My wife and I have always had different sleep/wake times. In our BF 9.6 the bed was open to the rest of the camper and with her going to bed early, and me staying up late, we had to hang dark towels at foot of the bed to block light, and I had to use headlamp to read and do stuff.
We now have a BF10.4 with the mid bath and it separates the living area from the bed area. Works so much better for us. She has her dark quiet bedroom at night, and I can sit at the table with lights on and radio playing low. Early morning it is just the opposite when she is up and I am in bed.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
burningman
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Bedlam
Moderator
Moderator
All the openings in my Host are framed which would make it difficult to enlarge openings without getting down to framing to modify it. I am not sure how this done in the Bigfoot.
bigfootgrey
Seems like a lot of work plus the cost of new windows for a small increase in window size. Not to mention the interior cornice,day night shades, and mini blinds size differences
2011 Ford F-350 PSD SC DRW
2008 Bigfoot 25C-10.4E
Firestone airbags - torklift stable-loads,fastguns,Talons Rancho rs 9000XL’s.
HMS_Beagle
I have the Bigfoot 10.4 that has the forward bath across from the fridge layout. They built a lot fewer of these I think so they can be hard to find used.
The windows I have explored on the BF are surrounded by some wood. To make them bigger, you'd need to cut out the shape, reef back the foam, and glue in wood at the new perimeter. How much bigger you can go before compromising structure too much would be a judgement call - I doubt Bigfoot did a lot of finite element analysis on the stresses.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Bradymydog
The mid bath is the reason I searched long and hard for a used Bigfoot 25C9.4SB. Four windows not counting the door. Back in to a campsite and enjoy the view. In addition a large skylight above the entry makes for a very bright interior. https://www.bigfootrv.com/images/2500_truck_campers/01_25C9.4SB.jpg
billtex
Bert the Welder wrote:
I certainly don't know, but if I was to make assumptions, I'd think the wood window framing would be part of the structure, if there is wood in there. You'd also need to be very sure there's no wiring in there, though that seems unlikely. Unless some here has your exact model and done it, I'd only be putting my trust in Bigfoot themselves for that answer!
Our old Okanagan is as you described. Bath and big closet at the bed, kitch. and f2f dinette at the back. I certainly does feel more spacious/open.
Your Okanogan is an Adventurer!
Anyway, IIRC Bigfoot is all glass construction, no wood frame. The only obstacle would be $.
Perhaps 54suds will chime in. He’s the BF expert.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Kayteg1
For structural questions - you should contact the manufacturer.
Newer campers do have aluminum framing, what should never be cut, when Bigfoot from what I read relies on fiberglass shell for structural strength?
Still cutting bigger opening in the wall can start lot of troubles.
I would rather add skylight, as this will give even more light without privacy concern.
Bert_the_Welder
:h 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
