Lights crazy with Headlights
Jthampton17
Here is the problem i am having. My 16 foot travel trailer brake lights, blinkers, etc work completely fine when my TV headlights are not on. As soon as i turn my headlights on, none of the blinkers work, no brake lights, i just get 3 solid lights on top of the trailer (that are indeed running lights) but no other light functions work.
My initial thought is open every light and look at the neutral wire in them to see if maybe one is bad. Any other opinions would be very helpful.
Thanks!
6 REPLIES 6
CavemanCharlie
Bad Ground.
But, just to freak you out. I once had a tail light bulb burn a filament out. When it did the burned out part of the filament touched the other part of the filament and made the lights do weird things like your describing. If you can't find a bad ground check out your taillight bulbs and replace them. This is one of those once and a million chances because it once happened to me I thought I would mention it.
daveor
another one for bad ground
Dog_Folks
The most common problem overwhelmingly with 12 volt lights is a bad ground.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
beemerphile1
There is no neutral. There is only hot/positive and ground/negative. I'd wager a bad ground between the trailer and tow vehicle.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Mark_Heisler
bad ground on trailer
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
carringb
Bad trailer ground. The other lights are just able to ground through your running lights when they're off
2014 ORV really big trailer
2015 Ford Focus ST
