May-24-2016 12:07 PM
May-29-2016 01:42 PM
May-26-2016 04:37 PM
May-26-2016 10:02 AM
May-26-2016 06:28 AM
May-25-2016 12:21 PM
May-25-2016 10:46 AM
May-25-2016 09:23 AM
May-25-2016 08:19 AM
Whangler wrote:
Now, these new LRE's run at 80psi. I reckon truck stop compressors will do the job but like gas stations, they're not always easily accessible. Do any of y'all use 12v tankless compressors when you're afield? If so, I'd like a recommendation for a good one. IF, that is you think it necessary.
Thanks,
Mars
May-25-2016 06:00 AM
Whangler wrote:
Thanks everybody. My last maxxis's didn't lose much, just down 1-2psi from 50 every 6 months or so. That said, my cheapo harbor freight 3 gallon compressor doesn't exactly make short work of topping them off. I can't imagine how it would labor to get from 77-80psi :-0
Rather than getting a dc compressor, maybe I'll just get a stronger one for home and keep my fingers crossed I don't need to air up afield.
May-25-2016 05:06 AM
2012Coleman wrote:Mandalay Parr wrote:I'm finding this hard to believe. I air up my Maxxis 8008 tires using my air compressor. I check them every 3-4 weeks, and they are always 5-10 lbs low.
I fill my once a year. A few pounds over so they last for a year.
Never have to add inbetween.
Weigh your trailer then go by the tire chart for the correct amount.
80 may be too high.???
May-24-2016 09:41 PM
Whangler wrote:
Soon, I will have my newer trailer, a 2014 Arctic Fox 25r. The first thing I do will be to take it to Discount Tire and remove the GYM's and put on LRE Maxxis 8008's.
My old trailer ran 14" LRC tires inflated to 50psi max. Even getting those up to pressure was sometimes difficult if I had to air up on the road using lousy gas station air. They held pressure very well, but once or twice I needed to bring them up a few lbs.
Thanks,
Mars
May-24-2016 09:34 PM
Lynnmor wrote:2012Coleman wrote:Mandalay Parr wrote:I'm finding this hard to believe. I air up my Maxxis 8008 tires using my air compressor. I check them every 3-4 weeks, and they are always 5-10 lbs low.
Good tires will hold air, what can I say?
May-24-2016 07:44 PM
May-24-2016 07:21 PM
