Feb-23-2016 06:51 PM
Mar-06-2016 06:34 AM
Mar-06-2016 02:43 AM
Fourkidletts wrote:
Hello! Trying this again, after finally abandoning the idea of a Ford Expedition. (Payload issues) We are in the market for a truck. We are considering TT's in the 25-28 foot range. ( We have a large family of 6, including 4 adults and 2 tall teen boys.
Questions:
1) I'm seeing possible payloads of close to the 2400-2600 lbs range with a 4x4 Ford F 150 SuperCrew.
Mar-01-2016 05:52 AM
travelnman wrote:
Its a problem. The old station wagons did the job. They could haul about
eight people pull 5,000lbs or more, get respectable mpg, fit in the garage,
and you could get huge engines over 400 cubes and burn regular. If you buy
a pickup my recommendation would be a GM product. I talked with a insurance
man at a camp ground who was also camping. He said the other manufacturers
have tricky engines to repair in accidents and don't stand up to collisions
all that well. I own a suburban and a Toyota. The suburban is one tough
old truck but I wish for more power. Remember in some communities you must
park a pickup in the garage or the neighborhood watch patrol will report your
violation of association rules. Disgusting but its true. With that bunch
I would go with a motor home and pull a toad. Watch the movie RV with Robin
Williams it will convince you the motorhome is the way to go with a family and its full of comedy situations we all experience camping. Of course they
probably won't let you park the motorhome on the driveway either so you will
have to rent a storage space or move to a farm.
Mar-01-2016 05:01 AM
Feb-26-2016 12:44 PM
Feb-26-2016 09:30 AM
carringb wrote:
One of the other interesting options is the ship-through code to Kerr Industries, which is a law enforcement upfitter, which makes me thinks this is the intended purpose of the 2500.
Feb-26-2016 07:56 AM
rjstractor wrote:carringb wrote:
He's right. GVWR went WAY up (11,00 pounds) but its fitted with the 6.0 and GM 6-speeds, it has a low GCWR.
That still sounds way low. IIRC the 6.0 with the 6L80E and 4.10 axle is rated for 18,500 GCWR.
Feb-26-2016 07:47 AM
Feb-26-2016 06:49 AM
That still sounds way low. IIRC the 6.0 with the 6L80E and 4.10 axle is rated for 18,500 GCWR, giving that 3500HD Suburban a 7500 tow rating fully loaded. Pretty impressive GVWR specs, first time I've seen a Suburban make full utilization of the HD pickup components it uses. It would really be a killer tow machine if they offered a Duramax/Allison option.
Feb-25-2016 03:28 PM
Feb-25-2016 02:52 PM
Feb-25-2016 12:07 PM
Feb-25-2016 11:14 AM
rhagfo wrote:Dadoffourgirls wrote:
GM is making a 3500 Suburban. Available only as a fleet vehicle. Rated to tow 3000 lbs. Priced from $80k.
a 3500 Burb, only rated to tow 3,000#. That would be more like the Payload. Tow rating should be in the 10,000# to 12,000# range.
Feb-25-2016 11:07 AM
Dadoffourgirls wrote:Grit dog wrote:
GM is making 2500 series Suburbans again. They're not setup as towing monsters and may be only thru fleet sales from what I read, but that may work for you.
Given your short anticipated towing distances, long term vehicle ownership and family situation, I'd still lean towards a crew cab pickup or big suv and deal with taking 2 cars for a year or 2.
But I'm in the won't have a van club. I need 4wd and a truck bed, never mind the cool factor.
