loud "pop" out of TT axles
clg82
On friday afternoon i was backing my TT into my parents driveway which is kind of steep and i was taking a pretty good angle at it, but when backing in I could kind of feel one of the tires binding and then a "pop" sound....i can almost compare it to what it sounds like when a detroit locker unloads under a lot of pressure...is this supposed to happen? to release the pressure on one side to allow the other side to turn? thanks for any help~Chris
29 REPLIES 29
camperdave
bcsslc wrote:
I grease shackles, springs and most of in between before every trip and it greatly reduces noise from trailer. I thought it was the hitch and ball at first.
I could (and do!) put up with a lot of creaky noises before I'd be greasing my suspension before every trip! :E It's enough that I'm supposed to clean and re-grease my Equal-i-zer (I rarely do...), no way am I doing that. :B
2004 Fleetwood Tioga 29v
camp4ever
brulaz wrote:
camp4ever wrote:
Is it a split axle? My split axles make alot more noise then the standard tandam axles
What's a split axle?
Some people call them split axles or spread axles.. Axles that are further apart then others.. Inside tire tread are around 18" apart
2003 Chevy Silverado 2500HD
2004 Ford Explorer w/ Towing Package
2014 Passport 2300 BH
CavemanCharlie
BarneyS wrote:
CavemanCharlie wrote:
I can only get mine to quit making terrible squeaking noises if I oil the equalizer bolts often. I wish they would have put grease zerks on places like that. I sometimes wonder how much wear the bolts in the equalizer have after all these years of moving dry.
You would be surprised! Take a look at this thread for some pictures of those bolts and bushings.:E
Barney
That's about what I would expect if I were to take mine apart if not even worse. The stupid axel manufactures should have made it right in the first place like the kit was installed in that thread. If I were going long distances I would install that.
BarneyS
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Highway_4x4
My Dexter plastic bushings were shot in a few years, I now have zerks on everything. It will outlast me.
2014 Ram Cummins Laramie, Crew cab, 4x4, Loaded, Snugtop camper
2014 OutdoorsRV Wind River 250RDSW
Big spoiled Bernese Mountain Dog
CavemanCharlie
Highway_4x4
mine used to pop all the time. Then I put on the Dexter EZ-flex and heavy duty grease-able shackles. Now it's quiet and flexes better.
elidodge
It's the spring equizer, that's the part between the 2 axles that the springs ride in. totally normal Bobby
mrekim
More distance between the wheels on each side - larger gap between tire treads.
mrekim
the_happiestcamper wrote:
No differential, so the wheels don't turn independently. Sharp turn will cause this. If it bothers you, then go back and forth, using a straighter angle.
The wheels are independent. The tub is just structural/hollow. No axle shafts.
brulaz
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
camp4ever
the_happiestcam
Me ('62), DW ('61), DS ('97), DS ('99), DD ('03)
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
clg82
Are there zerk fittings for all the grease spots?
