Maintenance free CCV filter for 2021 Cummins?
ShinerBock
We are already getting word that the L9 and B6.7 will have a maintenance free crank case breather/filter for 2021 along with several other updates. If this carries over to the Ram trucks(which it likely will), then no more CCV filter replacement ever 67k miles. The ECM will also be updated to CM2450 and will have increased computing capabilities which likely means more fuel maps for greater efficiency in more scenarios.
For those that do not know, 2021 is the start of phase two of the EPA's crack down on emissions in diesel trucks. Phase one for the past few decades has been centered around the emissions of these vehicles and phase two is increased fuel economy standards which these trucks have been exempt from until now. This is one of the main reasons why diesel manufacturers are adding things like 10 speed transmissions, higher pressure injection pumps, tighter clearances, and thinner oil. They all increase fuel economy/efficiency and they will need it now that EPA fuel economy window sticker estimates will be required just like the vehicles under 8,500 GVWR.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
8 REPLIES 8
spoon059
Lwiddis wrote:
“This is one of the main reasons why diesel manufacturers are adding things like 10 speed transmissions, higher pressure injection pumps, tighter clearances, and thinner oil.”
About time. Good!
Unfortunately that will also come with higher prices and the possibility of lower reliability.
2015 Ram CTD
2015 Jayco 29QBS
CaLBaR
FishOnOne wrote:
LIKE2BUILD wrote:
ShinerBock wrote:
...L9 and B6.7 will have a maintenance free crank case breather/filter for 2021 along with several other updates... ECM will also be updated to CM2450 and will have increased computing capabilities which likely means more fuel maps for greater efficiency in more scenarios.
For those that do not know, 2021 is the start of phase two of the EPA's crack down on emissions in diesel trucks. ...increased fuel economy standards which these trucks have been exempt from until now...diesel manufacturers are adding things like 10 speed transmissions, higher pressure injection pumps, tighter clearances, and thinner oil. They all increase fuel economy/efficiency.
That will be a nice improvement. Currently I can get 20-21MPG HWY driving my RAM solo. Not too bad for a truck that weighs 2.5 tons.
Improved efficiency will be great but let's hope we get reliability too. Don't want to repeat previous reliability issues of the last 15-20 years as new tech has been introduced in the trucks.
KJ
Factor in a regen and that 20-21mpg drops to a realistic 17-18mpg
17.8 hand calculated when I filled up today and had a regen on this tank of diesel. With cold winter weather and winter tires I can see it go up to nearly 20 once warmer weather and summer tires are on the truck.
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
FishOnOne
KJ
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
LIKE2BUILD
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
ShinerBock
ScottG wrote:
So a maint. free CCV adds to fuel efficiency?
No, I was just adding that part just in case why people didn't know why Cummins was making some of these changes. Not all of the changes are for fuel economy.
Cummins12V98
My 15 is looking better all the time.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ScottG
Lwiddis
About time. Good!
