Sep-16-2014 08:02 PM
Sep-18-2014 05:36 PM
woodhog wrote:
Why are just "truck campers" mentioned in loading instructions for these light trucks, all sorts of instructions for COG , pictures, stickers etc.
Nothing mentioned about other types of loads and their loading instructions.
Where there previous lawsuits at some time involving TC accidents or do they think hauling a truck camper is much more dangerous than other loads?
Sep-18-2014 05:31 PM
Sep-18-2014 04:31 PM
jimh425 wrote:
Isn't interesting that people don't trust TC manufacturers recommendations but are willing to believe whatever the Truck manufacturers recommend.
Sep-18-2014 02:51 PM
billtex wrote:mkirsch wrote:billtex wrote:
Copy/paste from our 06 Chevy Owners manual;
Here is an example of proper truck and camper match:
A. Camper Center of Gravity
B. Recommended Center of Gravity Location Zone
When the truck is used to carry a slide-in camper, the
total cargo load of the truck consists of the
manufacturer’s camper weight figure, the weight of
installed additional camper equipment not included in
the manufacturer’s camper weight figure, the weight of
camper cargo, and the weight of passengers in the
camper. The total cargo load should not exceed
the truck’s cargo weight rating and the camper’s center
of gravity (A) should fall within the truck’s recommended
center of gravity zone (B) when installed.
The "zone" in the picture (could not paste) is the entire wheel well...
Of course, the more mass you can shift toward the front axle the better the vehicle should handle as the majority will be over the rear.
B
It is NOT "the entire wheel well."
There are dimensions on the inside of the glove compartment lid that define the front and back of that zone.
My 2003 Chevy 1500 defines the zone as 0" to 78" measured from one end of the bed or the other. It has a 6-1/2' (78") bed.
IIRC my 2002 Chevy 3500 lists 0" and 96".
In the 06 manual it is shown as a zone the size of the wheel well...
Sep-18-2014 09:54 AM
Bedlam wrote:
I think running the tie downs against each other at the same tension will hold the TC better in place than relying on the forward bed wall with all four tie downs tensioning against it.
Sep-18-2014 09:22 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Sep-18-2014 09:12 AM
Sep-18-2014 08:50 AM
Sep-18-2014 08:16 AM
Bedlam wrote:
Wouldn't it make more sense to have the rear tie downs over the bed instead of pulling the rear over hang of the camper? Is Eagle Cap the only one that does this?
Sep-18-2014 05:45 AM
Sep-18-2014 05:19 AM
rickeoni wrote:Bedlam wrote:
I am used to seeing the rear tie downs at an opposite angle to the front and not in the same direction.
Agreed, with both tie downs angled in a similar forward direction this would cause the camper to be able to slide forward in the bed. Since the back wall of the bed is in the way it will lift in the back and dip on the cab over point. Probably not enough to do any damage to the truck but maybe a little to the camper, but sure will make for a scary ride on all but the smoothest surface!
Sep-17-2014 10:29 PM
Sep-17-2014 08:57 PM
Sep-17-2014 08:33 PM
deltabravo wrote:I think it is even more comical that people post some of this stuff as absolutely truth and factual for all trucks and TCs. My point being, I had none of this stuff in my owners manual, glove box, or TC manual. If I had none of it, how can someone tell me it applies to my truck or TC?cleary wrote:
Here's the camper loading instructions that came with my truck from Ford.
Chuck
Kind of comical that they show a drawing of an F150.
Toad: 91 Zuke
