Match truck and camper
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โMar-01-2016 09:30 AM
- Labels:
Truck Campers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 06:15 PM
d3500ram wrote:
I had to look twice but me thinks it is an optical illusion... there is only 1 top overload spring.
You're right. I zoomed in and it's the streak in the dust my eyes were seeing as the end of a shorter leaf. Never mind...
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 06:01 PM
My Ram 5500 is set up the same way, but has two upper leaf springs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 04:30 PM
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 03:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 02:52 PM
The lower overload is on both the F250 and F350. Until you compress the arch out of your spring pack, this spring does little. The lower StableLoad wedges are actually three wedge plates bolted together. This allows the lower overload spring to engage sooner and preserve more of the main spring pack arch. Based on the number of plates you use, you are also changing the preload on the lower overload spring. When this lower spring is engaged while you are unloaded, it results in a very harsh ride. Torklift created the wedges with a swing out hinge so you can disable your lower preload wedge when not carrying a load.
The photo you saw previously is the forward half of the spring and you can see the stabilizer bar end. This what the rear half looks like:
BTW: These photos were taken with my 4000 lb TC loaded, but only 5 PSI in the air bags and no trailer hitched up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 02:16 PM
Bedlam wrote:
To carry 7000 lbs level on the rear of my truck only required upper and lower StableLoads:
My apologies for the thread hijack, but can you explain what I'm seeing there. Is that a heavier leaf sitting on top of the leaf that engages with the Stableload? Do they separate as your springs compress?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 12:52 PM
You may as well get it as an F-350 and be done with it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 11:24 AM
Louisi wrote:
Thank you so much for the thoughtful very helpful comments, and the pictures, . Since we don't own a truck yet, we are going to look more seriously at the F350, it looks like that may be the way to go. Hope to see you on the road.
You will not regret getting a 1 ton...
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-02-2016 11:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-01-2016 02:42 PM
Get the camper package and 18" wheels whether you get a F250 or F350. The F350 will come with rear overload springs and 18" wheels standard but still need the camper package to get the rear stabilizer bar. The rest of the F250 is the same as the F350.
Air bags, shocks, 19.5" wheels and SuperHitch were added so I could tow my 8000 lb trailer behind the camper.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-01-2016 02:22 PM
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-01-2016 11:21 AM
Our 2007 F350 SRW carries our fully loaded Outfitter Apex9 (3000+lbs) and still sits slightly tail high without any suspension mods.
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-01-2016 10:59 AM
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMar-01-2016 10:29 AM
Lance 855S shows a "wet weight" of 3084lbs. Assuming that means with full fresh tank and propane, but nothing else like food or your stuff.
That's an awful lot for an F250. A typical F250 has a rear axle rating of 6084lbs, limited by the tires, and weighs in the neighborhood of 2800-2900lbs empty. So with just the bare essentials, you will be exceeding your tire ratings right from the get-go.
At the very least you will need some sort of suspension add-ons, and bigger tires right off the lot. To me, it's ludicrous to throw away brand new tires off a brand new truck, when you can just get the truck with the right tires to begin with.
If you upgrade to a single rear wheel (SRW) F350, you will not need the tires at least, and may not need suspension add-ons.
