Dec-05-2013 03:07 PM
Dec-08-2013 06:43 PM
Dec-08-2013 03:54 PM
Mike Up wrote:
The Ecoboost definitely has turbo lag, it's a common complaint on all the F150 forums.
I also wouldn't buy a truck to drive it like a grandpa
Dec-08-2013 11:05 AM
Dec-08-2013 06:30 AM
Dec-08-2013 05:40 AM
Dec-07-2013 09:53 AM
brulaz wrote:
Our 2005 VW Passat TDI definitely has turbo lag. Our F150 Ecoboost definitely does not, and you are the first person I've ever heard complain of it. Have you ever driven an Ecoboost or are you just extrapolating from older turboed engines? The Ecoboost uses a dual turbo or something like that to reduce lag, essentially eliminating it for me.
Turbo's are common in diesels and high performance gas engines. Like all components, some are more reliable than others. I have heard of no problems with the Ecoboost turbo, and the motor has been around for since the beginning of 2011.
The intercooler condensation issue apparently can occur after driving for a long-time in 100% humidity conditions and then stomping on the throttle. Built-up condensation in the intercooler is forced into the engine possibly causing it to stumble and stall. The vast majority of Ecoboost owners never experience it. I never have, perhaps because I rarely stomp on the throttle especially when it's wet.
An advantage of turboed over naturally aspirated engines is that they maintain their power at high elevations. Anybody who intends to tow in the Rockies will find this useful.
Dec-07-2013 07:21 AM
Mike Up wrote:
I decided against the Ecoboost because of the on going intercooler condensation issue that still isn't resolved to this day, I didn't care for the turbo lag,
I never have been a fan of turbo engines because of turbo lag, complexity, and poor reliability, but I was going to give this Ecoboost a try until I heard of all the overheating and intercooler issues it was having. They seemed to have fixed the overheating issues but the intercooler issues are even troubling the 2013s with complaints all over the f150 forums.
Dec-07-2013 03:41 AM
Dec-07-2013 03:16 AM
Dec-06-2013 09:59 PM
Dec-06-2013 08:54 PM
Dec-06-2013 08:18 PM
skipnchar wrote:
The so called 80% rule is complete nonsense. The truck is perfectly capable of towing 100% of its ACTUAL rating.
Dec-06-2013 12:51 PM
Dec-06-2013 09:20 AM
YankeeBP wrote:
I am new to RV-ing and would like some candid advice from some of you experienced RV-ers.
I am in the TV and TT research stage.
I plan to do some long distance towing. For example, Chattanooga, TN, to the Canadian Rockies and back (5000 plus miles). There will only be my wife and me, so we are thinking that we want a smaller ultralite TT (<= 24 feet).
I plan to tow with a Ford F-150 4x4 either with the 5.0L v8 or the v6 Eco/Boost. I am undecided at this point.
If I understand Ford's towing charts correctly, the F150 with the 5.0L V8 and a 3.55 rear-end has a maximum loaded trailer weight for towing of 7700 lbs. I have seen a recommendation that one not exceed 80% of that weight, which is 6160 lbs. I have not checked the same stats on the v6 eco/boost.
I would like to keep my TT as light as possible because I would rather be over-powered than under-powered. Consequently, I am focusing my attention on Ultralite TT's whose dry weight is in the range 3000 lbs to 4000 lbs. with a slide-out.
What experiences and advice can you give me?
Dec-06-2013 08:12 AM
