MPG's with NL 8-11
otrfun
Kinda curious what kind of mpg's we can expect on our return trip home next week with our new NL 8-11 on-board (OR to AZ). Expect to keep speeds around 65 mph. Estimate the total weight to be around 3,300 lbs. This is based on the scaled empty weight of other new units with the same options, plus batteries, 1/2 tank water, propane, tie-downs, and very little gear. TV is a '16 3500 SRW Cummins. Since we get a pretty consistent 21 mpg at 65 mph empty (flat, no wind), would we be overly optimistic in expecting, say, 14 mpg at 65 mph with the 8-11 under the same conditions? Thanks!
9 REPLIES 9
WyoBull
I get 11-12 mpg with my 2017 F350 6.2 gas and 3.73 rear end hauling our 8.11. Keep in mind, that is bucking no head wind. With the wind I am down to 10 mpg.
2017 Ford F350 XLT Premium CCSB 4x4 6.2 gas 3.73 rear end, 4226 lbs payload
2017 Northern Lite QC 8.11 SE
Torklift tie downs, Torklift Fast Guns, Torklift Upper Stableloads, Airlift 5000 Ultimate air bags, Airlift WirelessAIR onboard compressor system
PhilR
My 2013 Duramax w/ NL 8-11 gets 13-14 mpg.
Kayteg1
In highway hauling weight doesn't affect mpg much. Frontal area does.
Modern diesel should get 13 mpg with given parameter with no sweat, but speed plays huge role and that is where wind speed apply.
When I was moving from SF to Vegas, I made 3 quick trips with my cargo trailer.
All the same route, all the same 60 mph and driving S-E with 8-9000 load I was getting 11 mpg, while going back empty most of the time it was 9 mpg.
You can guess direction of desert winds.
FireGuard
11-13 mpg. Wind is the big factor.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
hedgehopper
When we drove our “new” 2002 Cummins dually with NL10-2 CD from Idaho to Denver, we got 15.5 mpg. But we were limiting our speed to 55 mph.
otrfun
Thanks everyone. Based on everybody's input I'm guessing we should expect 13 mpg---maybe a tad more. Not too bad.
FWIW, we used to pull a 13' 4" high, 12,000 lb. 5th wheel with a huge front cap and got a pretty consistent 11 mpg at 65 mph.
Homeless_by_Cho
Wardster wrote:
I would say that might be optimistic by 1-2 mpg, which is still pretty good considering the fact that you have a small efficiency apartment in the bed. I generally get somewhere in the 13.x mpg with the same TC in the bed of my '03 Duramax.
X2
I get 13-14 mpg with just the camper BUT I generally drive at 60 MPH max with the camper. I get about 20-21 mpg with an empty bed at 60-65 MPH.
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
Old_Days
I get about 11 to 12 MPH with a Ford F-250 6.2 gasser. So you should get 14 or 15 with a diesel.
Wardster
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
