โJan-31-2014 04:24 PM
โMar-18-2014 06:02 AM
โMar-18-2014 05:57 AM
โMar-16-2014 06:28 PM
โMar-16-2014 05:29 PM
wintersun wrote:jmtandem wrote:Posting this because people ask about the mileage:
First 300 miles: 12.2 mpg mixed driving. 2 days were in below zero weather and gas had 10% alcohol mixture.
My Ram/Cummins gets 20-21 mpg not towing. It gets 12 or slightly better towing.
You obviously did not purchase the truck for mileage. 12.2 mpg not towing???
Need to factor in that the diesel fuel costs 30-35% more per gallon at the pump. 12.2 MPG with gas has the same fuel cost as 16.2 MPG with diesel.
With my diesel truck I get 20-21 MPG on the open highway with no hills and no wind but that is the exception. Around town it averages 14.5 MPG so my fuel expense is more than that of the OP with his gas engine.
The OP paid $9,000 less for his truck and is paying half as much for maintenance so MPG is one factor but hardly the primary one in determining the total cost to own and drive a truck.
โMar-16-2014 05:15 PM
โMar-16-2014 04:23 PM
โMar-16-2014 02:09 PM
โMar-16-2014 12:28 PM
โFeb-02-2014 06:59 AM
โFeb-02-2014 06:45 AM
Perrysburg Dodgeboy wrote:campingken wrote:
20- 21 mpg with an HO Dodge dually?? Wow I really need a new calculator. Our 2003 non HO SRW 5.9 will hit sometimes hit 20 mpg if it's flat and the cruise control is set at 60 mph.
Man you are not going to like this then. My HO with 2WD and 3:77 rear gears hits 26 all day long at 60 MPH, the best it's ever done was 30 running behind a big truck from Perrysburg to Dayton Ohio. Note I said tucked in behind a big truck. And yes I ask him if he was good with it via the CB.
As far as the 6.4 only getting 12.5 it's not even broke in yet. My bet is it is going to top out at 16 to 17 MPG. Not bad for a big block Hemi IMO.
Don
โFeb-02-2014 06:23 AM
Perrysburg Dodgeboy wrote:FishOnOne wrote:Perrysburg Dodgeboy wrote:campingken wrote:
Are you sure about the 6.4 being a big block! :R
Perhaps big bore would be more accurate. :W
Don
Are you sure? I do not think the 6.4 is the same block as the 5.7. There is a 6.1 super charged Hime coming soon and it uses the same block as the 6.4.
Don
โFeb-02-2014 05:47 AM
โFeb-01-2014 06:18 PM
โFeb-01-2014 06:02 PM
