โApr-27-2020 09:54 AM
โApr-29-2020 10:29 AM
โApr-29-2020 09:27 AM
billtex wrote:bwlyon wrote:
Also the 18โ wheel tire combo will net the greatest tire capacity, avoid the 20โ wheels.
Both 18โ and 20โ tires available in LI 129 (4080#).
โApr-29-2020 09:05 AM
โApr-29-2020 08:49 AM
โApr-29-2020 08:45 AM
โApr-29-2020 07:51 AM
BurbMan wrote:
At the end of the day the real limiting factor is the 3450-ish max rating on an E-rated tire. Only way to get more capacity is 19.5 tire and G-rated or dually.
โApr-29-2020 06:24 AM
wnjj wrote:
3k is the wet weight with standard options. There is a list of options with their weights you need to include if you have any.
Our 9.5โ camper with slide specs out somewhere around 3300-3400 wet. It runs about 4k loaded up. I doubt youโll hit 4k either.
โApr-29-2020 06:14 AM
BurbMan wrote:
On the plus side, I brought the camper home with a 250 and it seemed to do fine
โApr-29-2020 05:53 AM
jimh425 wrote:
burningman knows better.
โApr-28-2020 01:16 PM
billtex wrote:
1 ton may have heavier wheels.
โApr-28-2020 10:25 AM
BurbMan wrote:
That is what I am thinking...Ram 3500 with 6.4L gas SRW long bed, either crew or extended cab. I can upgrade wheels and tires to give me more stability and footprint on the beach. No prohibition on duallies up here, but without spacers you can have rubbing issues when aired down.
The 3K is the wet weight, so I don't think we would get past 4k with just the two of us and some supplies. The whole idea of the TC is more minimalist, not packing like we are entertaining for 12 (which we frequently did with the TT).
But hey it wouldn't be camping if we weren't over GVWR right? LOL
โApr-28-2020 09:56 AM
โApr-28-2020 09:53 AM
jimh425 wrote:BurbMan wrote:burningman wrote:
All this sticker reading without knowing or looking at what parts are actually under the truck is gonna drive me right off of here sometime soon.
Hey I'm here to learn, so if you have some knowledge about what important parts I should be looking for please, please share!
burningman knows better. Maybe had too much/too little Corona. Sure, you can likely build a 2500 that is approaching a 3500 without the GVWR, but not all of us would want to bother when we could simply buy a 3500 if we want a 3500.
Sure, there are some 2500s that are close to a 3500 since you were talking Ram, but there are also 2500s with coil springs in the rear. Similarly, F250s and F350s have different spring blocks with the net result being more sag.
Finally, both brands can have different tires on the 2500s and 3500s which besides GVWR can mean you have a real difference in tires and actual RAWR.
Then, again, maybe heโs thinking of something else. ๐
โApr-28-2020 09:02 AM
burningman wrote:
Whatโs funny is the guy who originally had the camper had it on an โ80s F250.
Whatโs funnier is a SRW one ton is literally the same truck as a 3/4 ton.
โApr-28-2020 06:43 AM
