โJul-30-2018 01:21 PM
โAug-08-2018 05:35 PM
TxTiger wrote:rtreptow7 wrote:
could get in the same truck, a year newer, brand new...for $4K more after a trade.
That sounds like a pretty good deal. With 10,500 miles, comes out to 38 cents a mile in depreciation it's cost you. I don't see how the dealer comes out well on that. Normally depreciation is pretty heavy the first couple of years.
โAug-08-2018 03:47 PM
โAug-08-2018 12:46 PM
โAug-08-2018 12:27 PM
colliehauler wrote:rtreptow7 wrote:Isn't Chevy getting a all new truck for 2019? If so they ought to be out shortly.
โAug-08-2018 11:53 AM
โAug-08-2018 11:28 AM
โAug-08-2018 07:22 AM
troubledwaters wrote:
Bummer, if it was a TT you were pulling instead of a fifth wheel you could probably just get a loaner off their used car lot, or rent a 2500 for your trip. But needing a fifth wheel hitch makes all that extremely unlikely. But what the heck, I think asking for a loaner to pull a fifth wheel is still worth a shot; who knows, maybe they can hook you up.
โAug-08-2018 06:20 AM
โAug-08-2018 06:02 AM
โJul-31-2018 12:43 PM
rtreptow7 wrote:6.6 Oilburner wrote:rtreptow7 wrote:
Thanks. I did take it to the dealer for service. In fact it was scheduled to go in the following week for a recall on the axle nut. Something like checking the torque on the rear axle nut. I called and told him about the fluid and he said to bring it in right away and they would take a look at it. Glad I did.. They said the failure wasnโt related to the recall
So...your rear hub was loose and leaking oil, and it ruined the differential...... but it had nothing to do with the recall to check the spindle nut torque? Granted, the story has obviously got multiple layers of getting passed along from the tech, to the service advisor, then your words.... My guess is that it was direct result.
I'm certainly no mechanic, but I was thinking along the same line you were that there had to be a correlation? I was told that if it was a loose axle nut the gear oil would have been all over the outside of the wheel, not the inside? But like I said, I'm no mechanic. Once I get the truck back and talk with the service guy again and see the paperwork, I'll update this too.
โJul-31-2018 06:06 AM
โJul-31-2018 04:04 AM
โJul-30-2018 06:55 PM
