โJun-05-2016 10:22 AM
โJun-06-2016 01:50 PM
โJun-06-2016 11:02 AM
thcguy12 wrote:
Why dont we dump more often?
We lease some camping land to keep our trailer on from june 1 till october 31.
The closest dump station is two hours away. The camper stays on the land day and night for those 5-6 months. The only time it will move each year is when we move it two hours to mountain storage/dump station for winter. That is why we only dump ever six months.
Not sure a repair guy will come deep into mountains for repairs. The camper never goes to town.
LEAKS: how do you trace leaks if you can't see any water leaking inside from pipes. Cut into walls and floors? Sounds scary.
HEAT: tried running stove for a while and then trying heat. No luck.
โJun-05-2016 06:42 PM
thcguy12 wrote:OK, I'll try.
Plugged into to power....yes.
SEAM. By seam I mean outside where the vertical wall meets the floor/base. Right where those two meet. Its outside below where sink would be inside and below and to right of fresh water fill hole. No water inside.
โJun-05-2016 06:09 PM
Jack_Diane_Freedom wrote:
For dumping why not put in a redneck septic system as we did at our wilderness property. Dig a hole twice as wide as a 45 gallon drum, deep enough to cover with about 18 inches of dirt, punch some holes in the drum with a pick axe and cut a hole in the bottom for the sewer pipe. Put the drum in the dirt hole with the bottom up. Attach pvc pipe long enough to reach the surface through the hole in the drum, with an elbow. Fill around the drum with 1" to 2" stones almost to top. Fill with dirt and hook up trailer sewer hose and dump away. Has worked for years for us.
โJun-05-2016 03:22 PM
โJun-05-2016 02:16 PM
โJun-05-2016 01:42 PM
โJun-05-2016 01:13 PM
Just from seams of camper.
โJun-05-2016 12:35 PM
โJun-05-2016 12:18 PM
โJun-05-2016 12:11 PM
โJun-05-2016 12:08 PM
โJun-05-2016 11:41 AM
โJun-05-2016 11:36 AM
