โMar-30-2014 06:00 PM
โMar-31-2014 12:05 PM
โMar-31-2014 11:48 AM
APT wrote:Carhlr wrote:
Trucks payload is 1873lbs rear axle is 3:42 tongue weight of TT is 640lbs me wife and 3 kids I looked around I think I'll be right at the limit maybe just under.
No way you have 1800 pounds of payload. Check driver's door for this sticker for as equipped payload. I expect it will be about 1400 pounds.
That will be 8000 pounds with 900 pounds of TW when loaded up for a long weekend of camping. I see a new truck in your future.
Use Tow/Haul mode and M5, maybe M4. Get an Equal-i-zer brand 4-pt or Reese Strait Line WDH, not the friction sway standard WDH.
โMar-31-2014 10:16 AM
โMar-31-2014 07:43 AM
โMar-31-2014 07:31 AM
โMar-30-2014 10:10 PM
โMar-30-2014 09:38 PM
โMar-30-2014 08:58 PM
81SHOVELHEAD wrote:Carhlr wrote:
Trucks payload is 1873lbs rear axle is 3:42 tongue weight of TT is 640lbs me wife and 3 kids I looked around I think I'll be right at the limit maybe just under. I drive semi for a living so pulling a Trailer isn't new just wanted to make sure I had enough truck it has trans cooler, oil cooler, tow haul mode manual push button shift if needed I guess ill find out we pick up the new TT in 2 weeks. my main concern was from tongue to end is 35 feet I see the dreaded TT sway on the highway all to often when im passing one. I hope this set up will NOT have the sway
Ask your dealer if he will up grade the WD hitch to an equalizer 4 point hitch
I did on my 2014 Cougar 28 RLS (31 FT 7500 loaded weight) & we have zero sway issues
Mike D
โMar-30-2014 08:53 PM
โMar-30-2014 08:51 PM
โMar-30-2014 08:41 PM
โMar-30-2014 07:52 PM
โMar-30-2014 07:05 PM
โMar-30-2014 06:50 PM
