Can’t help you on the camper but I know it’s heavy.
I just bought a 21 Ram DWR and am looking for a TC but not as many out there as in the past.
I like the Bigfoot 10.4 but the only one on RV Trader is a new one “coming soon” for $70k!!! I’ll probably look for a clean Lance 981 or newer with a 975.
If you don’t have the truck I would skip the factory airbag option as I’ve heard it doesn’t work that well for a heavy TC.
I just installed my Torklift front tiedowns yesterday and should be getting my rear tiedowns and SuperHitch tomorrow. Pretty easy install but the drivers side takes a bit longer as you have to disconnect the parking brake cables and reroute them through the tiedown bracket. (Release the brake first to save time un threading the long bolt.)
These brackets are very beefy and probably weigh 10 lbs each.
I’m pretty sure the rear bumper steps will interfere with the rear tiedowns.
I’m going to try the Timbren suspension first and if more is needed probably go with the Stable Loads. Also have a Hellwig Big Wig from a previous truck I plan to install.
You will LOVE the new Rams!
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
