No Power - Unplugged from Shore Power
Tizi
Just got my camper set up after being covered all winter. The camper was plugged in with a small heater running to keep it from freezing. About 18 months ago I installed an upgrade to the converter/charger in my 2007 NL camper (PD4655 - 55 AMP Converter) from Best Converters. It worked great until I unplugged yesterday. I have no power when off of shore power. When plugged in, the batteries are getting charged and are totally full of charge. What could be causing this? Any help is greatly appreciated.
2008 Dodge Ram 2500 QC 4x4 - HEMI
2007 Northern Lite 10.2 RR
Tizi's Transformer by Whazoo
19 REPLIES 19
Tizi
It was the pigtail after all! I took it apart and rewired it. Everything works now!!!
ticki2
Delete
'68 Avion C-11
'02 GMC DRW D/A flatbed
DWeikert
Tizi wrote:
mkirsch wrote:
Do you mean running lights, like stop/tail/turn/clearance, or your porch light?
Also, you might want to start a new thread. Changing focus in the middle of an existing thread is nigh on impossible. People will read the first post and respond to that.
Clearance lights and rear running lights. Blinkers and stopping lights work.
In that case, ignore my suggestion. I was referring to the outside "flood" lights, not the running lights.
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
Tizi
jimh425 wrote:
Are the runnings lights on for the truck and is the truck running?
If not that it's probably the wire that goes to the running lights, the plug isn't in all of the way, or the ground. I guess you could have a switch of some type, but that's more unlikely.
Yes, the truck lights all work when running and when not running.
How do I check the ground?
jimh406
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Tizi
Tizi
DWeikert wrote:
My Northstar has an inside switch that turns power on and off to the outside lights. With it off, the switch on the outside lights appears to do nothing. Any chance you have something similar.
This is entirely possible. I have a switch like that, not sure if it controls the outside lights or not.
mkirsch
Nomad II
Nomad II
DWeikert
Dan
Tizi
it was the battery cut off switch for camper. However, my exterior lights are not working. I checked the fuses in the camper, had the pigtail tested, and my truck checked. Any ideas?
hedge
Any chance you hooked the battery up wrong? My converter has fuses for reverse polarity protection
2017 F350 Platinum DRW
2013 Adventurer 89RB
Tizi
Will try the switch when I get home. Does anybody know if there is could be an inline fuse at the batteries?
Bedlam
Moderator
Moderator
billtex wrote:
Try the battery cut off switch...
X2
billtex
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
