Odor when using tank heaters
DaveInVA
In my Arctic Fox 1150, I am getting an electrical/ plastic smell when I use my tank heater pads. Is this a common thing when using the heaters for the first time?
I plan to contact Northwood, but thought I'd pose the question here as well.
Thanks
7 REPLIES 7
DaveInVA
Thanks everyone. Talked to Northwood service guys and they said that the smell is part of the new tanks being used.
ticki2
You will often have an odor from any electric heater when first used . May or may not be something wrong . Keep an eye on it .
'68 Avion C-11
'02 GMC DRW D/A flatbed
mkirsch
Nomad II
Nomad II
Fresh plastics "off-gas" for months, perhaps years, until they're fully cured, and that off-gassing is accelerated when heated.
Grit_dog
Nomad III
Nomad III
^ lol this.
Are you heating empty tanks?
burningman
#1Flyboy wrote:
Is there any liquid in all 3 tanks? I’m thinking you might not want to heat an empty tank?!
That’s what I’m thinking, this could be a low beer intake issue on your part.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
_1Flyboy
covered_wagon
Make sure the vent pipes are sealed to the camper roof INSIDE or under the pipe vent covers. Most don't do that.... It not to stop leaks it's to stop the smell from reentering the cabin. They sometimes drill too big a holes and don't seal the pipe to roof underneath the rain cover. Then sewer gas go back in cabin.
This most likely culprit of all.
