โJun-16-2022 04:49 PM
โJun-18-2022 08:29 AM
โJun-17-2022 09:07 PM
blt2ski wrote:
Now that I think this thru a bit, there's no SWv19.5s mad in mass right now. Rims would be an issue with this option. Everything else should be an easy put together. Assuming a steel wheel option, should not be too hard. Outer rim is same as a dw. Need the center part designed, weld to outer rim...
Aluminum, would be another issue.
Marty
โJun-17-2022 08:19 PM
โJun-17-2022 07:28 PM
โJun-17-2022 06:06 PM
My swag, the big three could easily come up with 7500-8500 grawr setups, have 500 min more lbs of payload than an equal dw setup. My 286 65 18 tires on my 1500 are close to 4000 per tire. A 305 or 315 should put one over 8000.
Marty
โJun-17-2022 02:49 PM
MFL wrote:
Marty said: "Actually I like the "what if it were a front tire?"
Was a good question...Grit will be along to apologize pretty soon, nothing wrong with that! I would, if I ever offended someone unnecessarily. ๐
Jerry
โJun-17-2022 02:35 PM
โJun-17-2022 02:23 PM
โJun-17-2022 02:14 PM
โJun-17-2022 02:10 PM
JIMNLIN wrote:What if it was a front tire?
Fair question.....
Having made a living with SRW and drw LDTs pulling 15k to 22k GN/pintle trailers or 10k-12k bumper pull enclosed trailers I had my share of actual blowouts on both size trucks....front and rear.
A actual blowout or run flat on the rear of either truck simply wasn't that big of a deal even with a heavy fully loaded 22k gross weight trailer pushing the back end around. Good trailer braking kept the combo going straight till shutdown.
Front tire blowout ??? Now that is serious with a heavy trailer back there pushing the back of the truck one way then another even with good trailer braking.
โJun-17-2022 02:02 PM
I'll answer your question with a question...
What if you could actually add meaningful content when you post?
But to be fair, and not where you were going with your question, stock for stock, a srw has significantly higher front tire weight ratings than a dually where the front tires are closer to being maxxed out.
Having had one or two front blow outs, those are way worst than rear blow outs, be it a single or dual. I've had more dw blow outs than singles!
Reality, the safety factor of a dual vs single is only in the drivers brain. Otherwise there is no difference in any test I've seen, etc.
Reality, a super wide single is better option than duals. Less overall wieght per corner, better mpg, braking etc.
In the dot class 3 truck world, singles vs duals have a couple tiny better advantages. Overall, same gawr v gawr, the single is afraid of the game.
Marty
โJun-17-2022 01:58 PM
Me Again wrote:
Are there any SRW with more that a rear axle rating of 7,000 lbs?
I see many SRW trucks towing large trailers that I know have put the trailer over the truck rear axle/tire ratings.
โJun-17-2022 01:21 PM
โJun-17-2022 01:19 PM
โJun-17-2022 01:12 PM
