Power Tongue Jack Recommendations
Robobiker
I just put a deposit down on a small couples camper, 2024 Jayco Jay Flight SLX 195RB.  Am going to pick it up next week.  One of the first upgrades I want to do is a power tongue jack.  My last TT that I sold in 2020 had one I purchased from recommendations here.  It worked out well, but I can't remember the brand.  The new camper will only have about 400 to 600 lbs tongue weight.  Recommendations?
6 REPLIES 6
Hondavalk
82022 Super Brute Trailer Tongue Jack Trailer Jacks
Brand: HUSKY TOWING   This is what I bought 3 years ago. I like the auto stop feature so you don't have to worry about striping the gears out. When I bought it I thought who cares about a remote control. It's a great feature to have. I stick my level on the floor in the camper and can adjust the high. I would also recommend a weather proof cover to protect the jack.
JDsdogs
Nomad II
Nomad II
Gather the following. Loaded tongue weight, loaded tow vehicle weight and hitch to ground height. Give someone like etrailer a shout and see what the experts recommend. If you are not able to install it yourself, plan B would be to find someone in your area who deals with these tongue jacks and/installation. Having local technical support may be handy if you need it.
QCMan
Nomad III
Nomad III
Tongue weight is not the issue for a tongue jack. Keep in mind that you will be lifting the rear of the tow vehicle to instal the weight distribution bars. I do not believe that there is such a thing as too much jack. I also would not recommend anything less than a 2k pound capacity jack. The heavier your tow vehicle is the bigger capacity jack that you will need.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
You’re assuming he’s using wd bars? That trailer is dinky and lightweight.  Maybe OP has a midsize suv for towing but if it’s a full size anything, wd hitch is not needed at all.
idk why an electric jack would be any sort of measurable advantage on such a small trailer.
Maybe he has rotator cuff issues...the point is even the lightest duty electric jacks will have no issue lifting the tongue plus a bit of weight off the back of the truck. If not using a WDH, it's even easier on the jack.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Agreed, lifting the back of the truck a bit to relieve stress on the bars is likely the bulk of the load but on the other hand, even the weaker jacks are rated for 3500lb, so not likely to be an issue. It's not like you want to lift the rear axle of the truck off the ground, just take a few inches from the springs.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
