Propane tank question
plasticmaster
I have two 20# propane tanks on the front of my camper. Is it okay to have only one tank hooked up and the other fitting just dangling free while camping? I'd like to remove one tank and use it for my portable outside propane burner. Thanks.
7 REPLIES 7
opnspaces
Navigator II
Navigator II
Had a friend who's pigtail failed when out camping. So I unscrewed one of the pigtails off my changeover valve without any problems and let him run it all weekend. I guess as long as the cylinder that is currently being used does not run out of propane you should be good.
TheBeans
For what it's worth, always try to securely cover any open lines or connections for propane tanks with plastic or something. Believe it or not, spiders LOVE the odor of propane (who knew?!) and will make their way into your lines, fouling them badly and causing failure in the igniting components.
Wendy & Darrell
2014 Cougar Half-Ton 21RBSWE
2020 Ford F150
Hannibal
I carry a third tank in a plastic milk crate for the WeberQ. Iโ€™ve thought about going with two 20s on the TT for the convenience of swapping them out just about anywhere when I need a refill. Iโ€™ve never felt comfortable leaving one of the hoses open in our salty humid air.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
philh
In my former trailer (and adding to the new trailer), a tee off the low pressure line with a quick connect shut off valve. Important note, to attach to the device, it has to bypass the regulator. I did this with a separate line with regulator and quick connectors
WILDEBILL308
I agree with what Michael said. I would cap or tape a plastic bag over the open line to keep dirt and bugs out.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
LVJJJ
do it all the time
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
mgirardo
I don't know if it is a no-no, but I have done it without an issue. If your regulator has a tank selector, just make sure the selector points to the tank that is still connected ๐Ÿ™‚
Two seasons ago, our 20# tank that we use for our bbq grill and portable 2 burner stove went empty with a week left in the season. I didn't want to have it filled and let it sit all winter long, so I just removed one of the 30# tanks from the tongue and used it for the rest of the season.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
