Pump Question
martyn8677
Replacing the water pump in my 2004 Outfitter. Replacement is the new Shurflo 4008. The installation directions say I should have an adequate 50 mesh strainer (Shurflo 255 series). The pump I just took off did not have a strainer.
Do I need to order one before proceeding?
Thanks,
Marty
7 REPLIES 7
Old-Biscuit
JoeChiOhki wrote:
I've cleaned******out of mine more than once after filling up my tank off well water that had alot of minerals in it.
Should use an in-line filter(s) so 'clean' water goes in your fresh water tank
JoeChiOhki
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
Desertboy
Old-Biscuit wrote:
I have never found anything in any fresh water rv pump strainer.....ever!
How dirty is the fresh water tank :H
Guess 'new' there could be some plastic shavings from installation but I always full flush, drain & sanitize new. After that I don't worry.
Times 2 /
1969 AVION
3/4 12 VALVE
Freightliner/24' Flatbed 50,000 miles/ Titan 4000 receiver Hitch, no Mods needed.
Old-Biscuit
martyn8677
thanks for the responses guys.
dadwolf2
The Shurflo 255 strainer is readily available and only $10. I agree with Will in that I "shur" wouldn't let it stop me if I didn't have one, but if you wanted to get one it's really straight forward install.
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Desertboy
I don't think they are really delicate, it surely wouldn't hurt to have a screen on the intake side. They are a lot like the pumps I use on my sprayers and I haven't ever had a problem with trash getting in them. And I know for a fact it has passed through the pump before because it sometimes clogs my spray tips after getting through the system. The sprayers Im referring to are for herbicides, ( spraying hay meadows) You can add the screen later when you get one. I wouldn't let it stop the show.
1969 AVION
3/4 12 VALVE
