Dec-09-2021 02:47 PM
Dec-23-2021 09:36 AM
ajriding wrote:
I think if it were me I would go to a fiberglass forum, not a wood n stick camper forum for advice.
Dec-23-2021 07:54 AM
Dec-23-2021 07:51 AM
Dec-23-2021 04:28 AM
HMS Beagle wrote:
Fiberglass isn't a light material, if you made a structural shell only from solid fiberglass it would weigh much more. You would need to double or triple the shell thickness (and still reinforce high load areas), that would add ~500 - 1000 lbs to the camper. The sandwich construction takes advantage of the foam (already needed for insulation) and interior paneling (already needed for finish) to accomplish the needed stiffness without that increase in weight, and wood is a weight efficient (and cost efficient) reinforcement for areas that need it. Unfortunately it will rot. Ideally fiberglass hat sections or other methods would replace the wood, or a real structural foam would replace the styrofoam. And you can get that in a $200K camper - but not $50K camper. Bahn for example actually does build a camper shell like a boat - fiberglass inside and outside skins with structural foam core. The bare shell starts at about $50K.
Dec-22-2021 10:09 PM
Dec-22-2021 07:04 PM
stevenal wrote:ajriding wrote:
Built like a boat. The fiberglass is the structure. There should be no wood structures in these. Bigfoot is one brand.
Molded fiberglass campers and boats both need additional structure beyond the fiberglass skin. Whether or not there should be wood present, it is in fact present in a 'foot until it rots away.
Dec-22-2021 09:39 AM
Dec-22-2021 08:00 AM
Dec-22-2021 04:30 AM
Dec-21-2021 05:42 PM
Dec-21-2021 05:10 PM
ajriding wrote:HMS Beagle wrote:
The structure actually isn't fiberglass. The structure is a sandwich with a thin skin of fiberglass on the outside, thin luan plywood on the inside, and wood glued in-between to take the shear forces. Foam too, but the foam is quite weak compared to the wood. Each of the elements by themselves is weak and flexible, if any of these elements f... not without reason.
We are not discussing fiberglass siding campers, rather fiberglass campers, built out of fiberglass, not wood. Built like a boat. The fiberglass is the structure. There should be no wood structures in these. Bigfoot is one brand. Big difference.
Might be some wood under the floor, secondary structurer..
Dec-21-2021 01:28 PM
Dec-21-2021 11:32 AM
Dec-21-2021 11:09 AM
Dec-21-2021 11:05 AM
stupendous_man wrote:
Just finished checking out the Foot, unfortunately it didn’t go to well. The water damage was severe all throughout the camper. Just about every window, cabinet, and locker had water. Soft spots all over the walls and shell. Powerful, almost dizzying musty smell throughout, along with numerous interior seams pulling apart. Carpeting under the dining table was still damp, and much of the wood was either blackened from water, or just crumbling apart. One of the anchors was cracked, and another was completely separated from the shell. Surely the jack mounts were similar.
The sagging roof was probably water damage, as when I squeezed it, water dripped out of cracks in the roof hatch sealant. I offered him $3k and he countered with $6k, but to be honest I didn’t really want it at all after what I saw. Really disappointing, and a lot of expensive lessons. The owner was nice though, and gave me a snow cone.
