PUTC 3/4-Ton Premium Truck for 2017 Challenge
ShinerBock
Really not a shocker that the engine with the most power, the Duramax, did the best in the acceleration tests or that the Cummins did the best in the fuel mileage tests over the Duramax and Powerstroke. If being the fastest or the quickest is your main concern then the Duramax may be the way to go. If you don't care about getting up the hill a few seconds later and would rather have better fuel economy then the Cummins may be the way to go. The Ford is kind of in the middle with a trade off between the two, but with a nicer interior according to the judges.
GM - 3.73 rear end
Ford - 3.55 rear end
Ram - 3.42 rear end
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
25 REPLIES 25
demiles
MB, I'm not brand loyal and don't feel the same about Ford as you do about Nissan but the arrogance of some of they're owners is enough for me not to be associated with the name.
2008 Jayco G2 28RBS
2016 Nissan XD 5.0L Cummins
ShinerBock
transamz9 wrote:
The bad experiences can go either way. I had a Ford that I bought new and had 1 year. Six months of that year it was in the shop for major engine rebuild. Waited 3 months for one piston. Ford would not give me anything to drive while they had it because I didn't buy an extended warranty (so they told me). I'll buy a Nissan before I'll buy another Ford. Chrysler has always done me well but I have yet to have to deal with FCA. I get the run around from them I will change me thinking.
Yeah, I know many people that have those kind of stories with at least one manufacturer.
transamz9
Mortimer Brewster wrote:
Any of the big three would be a solid choice for a truck. The Nissan would be a good choice for someone wanting to start an artificial reef.
Nice display of ignorance MB. As noted in the article it sits as a very capable heavy half ton truck despite being at the bottom 2b class.
My experience with Nissan is that they DO NOT stand behind their product. I had a problem with an Altima involving motor mounts going bad. I had 2 dealers tell me that it was covered by warranty. Corporate Nissan said it wasn't covered. They then spent 3 months dodging my phone calls. I would leave them numbers and times at which to reach me. Typically they would leave a message at home during even though I had given them a number and time period to reach me at work. This happened multiple times.
Contrast this with my experience with Ford. My Explorer has unfortunately had more problems than I would ideally expect. Ford has been fantastic about standing behind their product! Kudos to Tom Peck Ford in Huntley, IL. So on one hand you have a company who works hard to satisfy their customers. On the other you have you have Nissan, who worked hard at not standing behind their warranty.
I will admit to ignorance in that I bought a Nissan. I guarantee that I will never repeat that mistake. I'll also retract the comment about using a Nissan to create an artificial reef. That's a crappy thing to do to a fish.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Mortimer_Brewst
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
boshog
Bionic Man wrote:
We have come a long ways when you look at the specs and see 800 lb/ft of torque, and it is a 100 lb/ft deficit to its main competitors.
These are the good ole days.
But you have to wonder how much of this power is getting to the ground, and for how long, and when. Look at the recent dyno pulls TFL did and the delta between the GM and the other two. With torque management it is difficult to tell unless someone did an actual study. There is a test result I'd like to read, hear that TFL?
Bionic_Man
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
ksss
OK, that is pretty funny!
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
larry_barnhart
ShinerBock wrote:
larry barnhart wrote:
Never tells what truck drives the best. I always feel this is important to me and the reason for driving GM products. I will say our 98 2500 dodge drove good for the 14K miles we owned it.
chevman
I think that is because each is best in their own way and what may be important to one may not be important to another. Some may like to have the quickest truck and not mind sacrificing fuel economy for it. there are those that may feel that fuel mileage is more important over performance just as long as the truck can tow what they need it to at the rated speed limit. Others may want dependability above all else.
Each of these truck are close yet very unique in small ways. The GM is the sportiest of the trucks, the Ram is the truckiest of the trucks while the Ford is somewhere in between with a smooth ride. Then there are those that just buy based on brand and it doesn't matter what the other truck have because their brand is always the best. I try not to talk with these kind of people because logic and rational thought usually go out the window in those conversations.
. I feel the same. Chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Good stuff....
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
demiles
2008 Jayco G2 28RBS
ShinerBock
chevman
larry_barnhart
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
Mortimer_Brewst
Don't hold back, tell us what you really think........:B
That actually was holding back.
thomasmnile
